Results 1 to 10 of 18
Thread: Little Help Need Please WITH SUB RMS AND AMP
    Mar 2007
    Exclamation Little Help Need Please WITH SUB RMS AND AMP
    Hi there ..
    This is my first post here so Hi all..
    i just got a new sub as all my old gear got robbed out the car...
    The sub i have is - SONY XS-L122P5S
    http://cgi.ebay.co.uk/Sony-XSL-122P5...QQcmdZViewItem
    but i have a unknow amp is say's its 480 watts on the amp its self
    So that must be briged. I have this sub briged bus that sub is only 380 RMS
    will this reck my sub up
    don;t really wanna kill but i want it to sound heavy bass as it does know when turned up as i have a wack headunit for aldi £40 still really good tho
    Alsp is there any info about RMS and that base ware to have car sub's with MAX bass
    And 1 last thing...
    Is there anyway i can read what watt's car coming out my amp with somthink
    thanks
    Newbie getonerd's Avatar
    Dec 2005
    Ohio
    480 max
    240x2 max
    it might be 120 rms
    thats not a good for a sub maybe some 6x9's
    2005 Pontiac G6
    Headunit: AVH-P3100DVD
    Front speakers:Infinity 6022i
    Rear speakers: Powerbass pb-b6.5xv.2
    Battery: top of line walmart brand(LOL)
    Wiring: 1 run of 0 ga
    Amp: MTX JH600 & Lightning Audio B300.4
    Sub: TS-W2000SPL
    MySQL Error scott_fx's Avatar
    Dec 2004
    Los Angeles Ca
    that will probably wreck your sub because it's not powerfull enough...you'll probably push the sub too hard by turning up the gains to get the sub louder. that'll cause a distorted signal and that is what will blow up your sub.
    get a good quality amp and sub and be done with it. I have a rule of thumb of sorts... cheap gear will cost a lot more then good gear. Meaning that cheap gear will break a lot easier/quicker then good components and will require you to replace stuff more often... costing you more in the end.
    New System in progress:
    M10k
    Phaze TD1500 ~> Seas g18rnx/p
    Zapco Ref 500.1 ~ 12" tc-9
    Transflective Xenarc
    My Car Pc Install
    My Boat Pc worklog
    Newbie supraman22's Avatar
    Feb 2007
    ^^ what he said. I know alot of people who underpower thier subs by alot. For example i have a friend that has the amp you are talking about, most likely a dual amp, and then he has RF P2's. Throw the old amp out and go searchin. Match your sub with your amp, rms wise and if you can get ohm's try and match that also. About the best thing you can do is look into stuff, as i have found the best tool sometimes is trial and error. I've been driving for a little over a year and ive had numerous combonations or subs and amps. I'm finally settled though.
    Right now i have 2 infinitys, 300 rms each approx., my rockford amp is 300rms approx. Matching is the key.
    Are you planning on bridging the sub??
    Rockford Fosgate 5002 (subs)
    (2) 12" Infinity REF1252
    (2) Pioneer TS-A1681R 6.5
    (2) Pioneer TS-A4670R 4X6
    (2) Polk Audio 2" Tweeters
    Mar 2007
    yes im looking to do what ever brige the sub i want to use it to its full power looking at amp now i never new they had RMS i thort it was just sub No wounder Ther sub is so low
    So if my sub is 380 RMS 1300 MAX WATTS
    Then is say on the box recomed power is 300 RMS continous power
    So i need to look for a amp with say 360 RMS does now matter what the max watts is
    Can some one tell me a good nice priced amp i can run this sub on as its very very fine
    i allways thort u matched the amp 400 watt to the subs 400RMS
    But its the amp RMS to the subs RMS
    but i don;t understand the ohm
    Feb 2007
    how much are you wanting to spend on an amp, knowing that, there are probably alot of suggestions people could give you.
    pioneer, sony, fosgate, xtant, mtx, all carry amps to match, but there is a wide variation of pricing.
    Mar 2007
    i just wanna ge the best from my sub real so if the sub 380 RMS 4 OMS
    What kina amp am i looking for
    360 RMS 3 OMS??
    i fpound this amp
    Boss Audio 760W
    320 Watts RMS Bridged into 4 Ohms
    http://cgi.ebay.co.uk/ws/eBayISAPI.d...1004&rd=1&rd=1
    This not power fully enoight for my sub ?
    Dec 2004
    Los Angeles Ca
    like suggested before stick with name brands (not boss)
    check out the Infinity REF611A it shouldn't be too expensive or if you can get a 2 ohm sub (or dual 4 ohm voice coils) check out the Infinity REF311A. they aren't terribly expensive and should last you
    M10k
    My Car Pc Install
    My Boat Pc worklog
    Mar 2007
    i see http://cgi.ebay.co.uk/INFINITY-REF61...QQcmdZViewItem
    456 watts RMS x 1 channel at 4 ohms and ≤ 1% THD
    my sub is on;y 380 RMS this ok
    Mar 2007
    i still don;t really get it what kind of RMS am i looking for my 380 RMS sub
    Do i go a little higher or lower some people say hi and some say lower
    i wanna keep the sony sub as its really nice
  1. Could my amp be bad or did i miss something?
    By sansoo24 in forum Car Audio
    Last Post: 03-05-2007, 02:45 AM
  2. if amp outputs 600w, and sub is 500w RMS...good/bad?
    By senseless228 in forum Car Audio
    Last Post: 09-08-2006, 06:00 PM
  3. WTB: 4x > 50 watt RMS amp
    By spazegun2213 in forum Classified Archive
    Last Post: 09-26-2005, 10:58 PM
  4. FS: Rockford T10001bd mono block amp (1000watts RMS at 1ohm)
    By therussman2002 in forum Classified Archive
    Last Post: 07-26-2005, 10:29 AM
  5. I need to some basic information about amps
    By Bust_A_Cap in forum Car Audio
    Last Post: 08-01-2004, 10:31 PM
