Results 1 to 10 of 12
Thread: Ground connects to frying pan?
    Apr 2006
    I aim to test my sub speakers & amp in my living room before I plug the whole thing into my car, by what should I connect the ground wire to???
    I have it wired to the handle of a frying pan, but am too scared to flip the switch incase I blow something...
    Takes it in the Rear kevinlekiller's Avatar
    Dec 1969
    Where the penguins and polar bears live.
    What source of power are you using?
    Apr 2006
    Quote Originally Posted by kevinlekiller View Post
    a 12v multi adaptor which plugs directly into the mains... I chopped one of the ends off and connected the bare wires to the amp (positive & negative).
    Mo' Programming Mo' Problems
    Sonicxtacy02's Avatar
    Woodbridge, VA
    Blog Entries
    32
    please youtube this. lol
    Live mp3Car Facebook Chat
    Dec 1969
    That wont supply enough power, and no dont use the ground from a frying pan
    You need something that supplies lots of power ( a multi adaptor supplies at most 1 amp of power ).
    Use a car battery or something.
    Apr 2006
    oh man, it says 300mA on the adapter and 3.6VA max (dont know what that is)...
    Maybe if i get a few more multi adapters, cut the ends off, and wire them all up to the amp... I may need a few hundred or so right??? Ok scrap that...
    So whats a good alternative? I really dont wana buy a car battery, and the one in my car is a pain to get out...
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    450w ATX power supply. Just use the 12V Rail. you will need to ground the Power OK lead. If you search there will be a thread (or more) mentioning how to do it.
    It's how I run my test CarPC indoors at present.
    Frying Pan hehe, sounds like a nomination for the darwin awards might be on the cards.
    Dec 1969
    Quote Originally Posted by ijwalla View Post
    You can do it like enforcer says, or use a old AT power supply to do it even easier, that has like 10+ amps on the 12v rail.
    Car Audio Moderator durwood's Avatar
    Sep 2006
    Chicagoland (St. Charles,IL)
    There is an article in the wiki on using a computer PSU to power 12V. You won't be able to really turn up the volume though. Make sure to put a fuse on the 12V line equal to what the PSU can actually put out. Good luck. Record it just incase something good happens. I would ahve loved to see the frying pan idea
    Woodbridge, VA
    Blog Entries
    32
    you can get a wal-mart battery for around $30 bucks. Why not go the safest and easiest route.
  1. Induced noise/Ground loop trouble shooting guide.
    By Will Albers in forum Car Audio FAQ
    Last Post: 01-28-2011, 09:37 AM
  2. Alternator Whine Only With Carputer
    By tbird2340 in forum Car Audio
    Last Post: 06-29-2007, 03:36 AM
  3. Inverter Question
    By phatchink in forum Power Supplies
    Last Post: 08-21-2006, 01:45 PM
  4. I tried everything, can't get rid of this ground loop
    By intense in forum General Hardware Discussion
    Last Post: 07-10-2005, 09:58 AM
  5. Pinout Color Codes / Tables
    By gummybear in forum General Hardware Discussion
    Last Post: 05-12-2005, 04:05 AM
