i'd update your drivers before you do anything else
I have the carPC mounted, both amps and all speakers running. Whether the car is running or not I get a strange kind of static/popping sound that alternates between right/left channels...almost like a bad MP3 ripped file. I checked all the grounding, looks good....Do i need to ground the actual carPC case itself?
BTW, the sound is only when audio is playing.
New System in progress:
M10k
Phaze TD1500 ~> Seas g18rnx/p
Zapco Ref 500.1 ~ 12" tc-9
Transflective Xenarc
My Car Pc Install
My Boat Pc worklog
the amps arn't on metal right... just covering bases...
what kind of sound card are you running? I had the same problem with a sound blaster usb, it ended up being the input on the usb sound card.
Aron
Absolutely 100% stock
USB Live! 24bit external...
also try swaping out the usb cable, slim chance but it might work
Aron
I'm having the same problem..any other suggestions?
this is driving me crazy!
