The HIGHER the guage number, the THINNER the wire. Kinda counterintuitive, I know. You COULD do what you are asking. But its not really good practice. If you are going to do it, do this. Run your 10 or 8 awg from the battery into the trunk. Make sure you put the requiset inline fuse just after the battery. Now you'll need a 12volt switch that will accept 10+awg wire? I just don't recommend it. I would run seperate wires like I suggested. Its a LITTLE extra work and its a lot safer and easier in the long run. AND, you'll at least have the added switching of the ignition. Remember, if you use a switch on the constant hot feed of the battery, ALL DAY when your car is not one, the switch is heating and heating.
LinkBack URL
About LinkBacks
