Results 1 to 2 of 2
Thread: Honda Prelude 97 Amp Power Wire problem
    Mar 2007
    I'm in the process of installing a subwoofer/amp in my friend's 1997 Honda Prelude. For who's done it, how did you get the power wire from the engine bay to inside the car? I've been looking for a hole, but can't seem to find one!
    FLAC J187's Avatar
    Nov 2004
    Boston
    There is definitely a hole somewhere in that firewall, but you can easily enough drill a new one. Drill a hole someone w/ easy access and clearance form potential hazards of driling. Use a rubber grommet that fits the hole nicely and fits tightly the wire you are running. Run the wire from the battery and into an inline fuse, then run the wire from the fuse through the hole into the car. As far as more on this process goes there are probably a million pages on the net and probably tons w/ pics. Other than that, find a hole already there with a large water tight grommet and put a small slit in it just to the side of the existing wire, just big enough to carefully pull the wire you are running though. Make sure the seal stays tight.
    Its not the cards you're dealt, its how you play the hand!
    Quote Originally Posted by ryuandwings View Post
    Where can I get a roll of tin foil?
    I been looking for that all over the net, but I can't find it.
    Please help.
  1. Alternator Whine Only With Carputer
    By tbird2340 in forum Car Audio
    Last Post: 06-29-2007, 03:36 AM
  2. FAQ: Power Supplies Explained (Part 1)
    By Bugbyte in forum The FAQ Emporium
    Last Post: 06-10-2007, 08:45 AM
  3. Power supply Problem
    By xGROMx in forum Power Supplies
    Last Post: 03-16-2007, 02:19 PM
  4. M2 ATX Power on problem
    By JWise1203 in forum Power Supplies
    Last Post: 07-26-2006, 12:24 PM
  5. PC power button problem
    By BMp3W in forum Power Supplies
    Last Post: 10-12-2002, 03:36 AM
