Results 1 to 5 of 5
Thread: RCA's Blown?
    Mar 2007
    Question RCA's Blown?
    i am running a 2000 watt amp bridged between two 1000 watt ppioneer subs... i just bought another amp to run my 6x9's and i unhooked the wiring form my 2000 watt amp too test this amp i just bought and it worked for a litle while then i changed the speaker wires around while the music was going and the speakers went all crackly... it isnt the speaker cause i re ran them through the head unit to test them and they worked fine...
    i ran the wires back through my other amp and it had the same effect... could it be the rcas or something else?
    thanks
    Maximum Bitrate boomintrac's Avatar
    Apr 2005
    2hr west of Chicago
    It could be I would reccomend taking the rcas out of the car and physicaly twisting them to remove any unwanted noise. Let us know if that works for ya!
    Aron
    Absolutely 100% stock
    FLAC J187's Avatar
    Nov 2004
    Boston
    Did you at some point hook the new amp to the subs? Sounds like maybe the amp clipped? Depending on the speaker, it could still be blown speaker(s) causing the problem...even though you checked them through the HU, depending on a few factors of the speakers, the HU may not be sufficient power to reproduce the crackling, although the speakers may actually be blown. For what its worth, you shouldn't be juggling wires around on your amp while it is being used to produce music. You could have blown the speakers by connecting the new amp to those power-hungry subs and clipping the wave, or connecting the 6x9s to the monster amp. You could have blown them simply by not adjusting gains properly or by underpower them. It might be an RCA issue or even reverse polarity. Did you maybe mix up the + and - on the speakers, that could do it.
    Its not the cards you're dealt, its how you play the hand!
    Quote Originally Posted by ryuandwings View Post
    Where can I get a roll of tin foil?
    I been looking for that all over the net, but I can't find it.
    Please help.
    Mar 2007
    yer thanks i know for certain it isnt the speakers and dont think it is the rcas...
    i have a fuse for the remote wire on the back of my head unit which i think could be blown..
    and yes i hooked the postives and negatives up coreectly..
    thanks..
    FLAC J187's Avatar
    Nov 2004
    Boston
    IF the fuse was blown you wouldn't hear crackling, you wouldn't hear anything. Still as night. Has to be something else. Start as basic as you can and add comonents until you've found the problem. Add one channel, one speaker, the other channel, like that.
    Please help.
  1. Blown CCFL Inverter
    By Jagaer in forum LCD/Display
    Last Post: 02-03-2007, 03:34 AM
  2. New ebay LCD
    By shahin_xp in forum LCD/Display
    Last Post: 12-03-2006, 04:21 PM
  3. RCAs for sale, Monster Cable and Esoteric Audio
    By PearlR/T in forum Classified Archive
    Last Post: 09-10-2006, 07:31 PM
  4. Speaker Blown???
    By 3onDubs in forum Car Audio
    Last Post: 03-10-2006, 12:55 PM
  5. Sony stacker RCA's
    By Vicked in forum General Hardware Discussion
    Last Post: 11-05-2003, 01:51 AM
