What kind of MB you using? I know with the M10000 you can set all three of the audio connections to do 5.1 so you wouldnt have to split the RCA's
Brasil in 2007...
the M10000...how do i set that up? Thank you for your fast reply
Brasil in 2007...
http://www.via.com.tw/download/mainb...IA-M_v1.40.pdf
Give this a shot I can only spoon feed half of the way. Search is your friend! Its always good to have a manual on hand also but this should set ya up
Aron
Absolutely 100% stock
There is a sticky too. "How to get 5.1 out of your via board" or something close.
1.9in x 2.9in -- 47mm x 73mm
Thank you very much guys, I am looking into that pdf at the moment! And so I guess what I need is to set it up as a 5.1, correct? If its not set up as a 5.1, will splitting the RCA mess things up? Scary when it comes down to burning your hardware!!
Brasil in 2007...
Thanks for the pdf, it was easy to understand, and I am working on my amps today still! Thank you again
Brasil in 2007...
