Results 1 to 5 of 5
Thread: PC to Amp Issues - Distorted sound
    Newbie mordz's Avatar
    Mar 2007
    Hi Guys
    I have an Audi S3 (Bose amplified)
    I have purchased the audio harness to convert the standard head unit connector to 4xRCA input so the sound goes to the amp. i have tested by hooking up a Sony Head Unit to the RCA's and playing a CD - works fine.
    However from the PC output the sound is very distorted and only comes out of the sub. no matter what RCA i connect it to it just comes out of the sub.
    Is this because the PC outputs an amplified signal? and not a preout? I.e Low and high level inputs - can i convert the high to a low? are there any external sound cards that have a low output (think the onboard is crap anyway) what about a head unit with a 3.5mm jack aux in that also has 4x RCA pre outs for an amp.
    How can i get round this.
    Mar 2007
    so yeh, maybe the PC sound output is too low? 2v i read yet i may need 5+v to drive the amp.
    would a line driver help
    such as the http://caraudiosecurity.com/shop/pro...s_id/3862.html
    Constant Bitrate pate60's Avatar
    Jun 2004
    Auckland, New Zealand.
    yeah you need to use high level inputs to your amp if you do not have any you can buy a level converter. You could try and turn the wave volume level way down within windows, so then using your front end your end up changing the main volume level, this may help.
    you may also wanna check the settings on your amp.
    Car Audio Moderator durwood's Avatar
    Sep 2006
    Chicagoland (St. Charles,IL)
    The computer outputs low level signal. You should be able to connect the output of your soundcard directly to RCA jacks of your amp. I don't understand how you have your computer connected to your stock radio. You never mentioned that. You need to provide more info.
    Mar 2007
    hi guys, i have the following harness adaptor.
    http://www.nexxia.co.uk/Car_Stereo_f...ts/Audi/A3.htm
    i had plugged the 2 rca's from the pc into just the rear connectors for the harnes and sound was awful as it was in any other combination.. i have purchased some rca Y adaptors and sent L to FL RL and R to FR RR
    http://www.maplin.co.uk/Module.aspx?...aptor&doy=15m3
    works ok - tho onboard sound is crap.
    must have been a grounding issue maybe?
  1. Sound hooked up, having USB and popping issues
    By dbzeag in forum Car Audio
    Last Post: 05-28-2006, 03:38 AM
  2. Replies: 9
    Last Post: 08-07-2005, 12:27 PM
  3. Replies: 25
    Last Post: 08-04-2005, 12:49 PM
  4. Replies: 0
    Last Post: 08-28-2004, 04:14 PM
  5. Another pc sound -> car speakers question
    By Juz in forum General Hardware Discussion
    Last Post: 10-17-2002, 12:47 PM
