Results 1 to 7 of 7
Thread: VIA M10000 Sound Problems
    Jan 2007
    Columbus, OH
    I am only getting audio out of the right channel and not the left channel. I have the shunt jumper the middle pins. Is there supposed to be another shunt on there somewhere. The manual says that there are 2, while I only have one. Also when I connected my sub amp to the mic jack after configuring everything it is still putting music out of my 10" sub, when I just bass only. Any ideas? If I choose bass only it is very little bass at all. When it's putting out the music it's hitting really hard, but it's barely pulsing if I choose uncheck exchange LFE
    Mar 2007
    Los Angeles, CA
    Yes. Pins 5 and 6 (the middle two pins) AND 9 and 10 (the right 2 pins if you are facing the rear of the motherboard) should both be jumped. This would explain why you are getting one channel.
    The sub is probably getting a summation of the 2 channels; if you are only sending one channel of audio, this may explain the weak bass.
    You can pick up a pack of "mini jumpers" at your local computer electronics store.
    Jan 2007
    Columbus, OH
    I am really made now. I installed everything over the weekend. It was working and everything was great I turned the key off, it shutdown and everything was still good then a little bit later I went to turn it on and I no longer have sound. The pins are jumped correctly and device manager says: device is unable to start.
    Mar 2007
    Los Angeles, CA
    I hope you didn't jump the pins with your atx power cable attached? You could have shorted something out?
    I would also try removing your audio drivers and reinstalling them.
    Jan 2007
    Columbus, OH
    No, I meant I jumped the pins before I installed it. As I bench tested it for a couple of weeks before I installed it. I tried uninstalling the driver but that didn't seem to work, I'm going to try it again though. I'm wondering how much sound quality difference there is between the VIA VT1616 and just a pci sound card with front, rear, and sub outs
    Mar 2006
    Colorado, but Canadian!
    Quote Originally Posted by mdlesk View Post
    a cheap PCI card sound the same if not a bit better than any onboard.
    1.9in x 2.9in -- 47mm x 73mm
    Jan 2007
    Columbus, OH
    I went to Microcenter today and picked up a PCI 5.1 Sound Card for $20...I'm working on tuning it right now.
  1. Replies: 8
    Last Post: 04-05-2006, 09:28 PM
  2. EPIA M10000 and Sony CDX CA900 Sound Trouble
    By paulpitchford in forum General MP3Car Discussion
    Last Post: 01-28-2005, 06:48 PM
  3. Audigy sound card problems
    By TimmyM in forum General MP3Car Discussion
    Last Post: 07-26-2004, 10:33 AM
  4. got sound?
    By masch in forum Newbie
    Last Post: 11-17-2003, 10:01 AM
  5. epia m10000 sound quality
    By hijinks21 in forum General Hardware Discussion
    Last Post: 06-05-2003, 06:07 PM
