No, those wont' do for what you are trying to do. You are going to want a steeper attenuation than that. I would say normally, for components, you'd like to stay at least 2nd order, 12db. IN the case of stock speakers, I'd actually try to go for a 3rd order slope to sharply cut those frequencies. NOt just for safety sake, but for sound sake as well. Remember, factory speakers are designed to be more or less full range from the signal. The drivers play something like 20-180 or something. This is done because car manufacturers either generally don't include a sub or if they do not a powerful one, so they rely on using lightweight coned drivers with high sensitivity to reproduce ALL of the frequencies below the HP point, or at least as much as can be safely. I really haven't used a ton of AM passive stuff, but I would look into the dayton stuff from partsexpress. Its bound to be affordable and probably will give you 3rd order attenuation. After all is said and done, you may find a need for a an audiocontrol active crossover as well, depending on well your eclipse amp handles it all and how well those stockers respond to the frequency split. Aside from those dayton products, I'd say if you look elsewhere just look for a passive xover with a sloope of at least 12. Me, I'm going 3rd order considering the speakers are stock.
LinkBack URL
About LinkBacks
