Results 1 to 10 of 10
Thread: Help need PLEASE - with sub making a poping noise
    Mar 2007
    Hi there..
    I get a poping noise from my sub when i turn my back window wiper off
    when i turn it on its ok then turn it off and get like a DUFF!!
    I have it earthed to the back lights bolt could that be the problem..
    i did not think it would be that
    FLAC XC-C30's Avatar
    Jun 2006
    Abele, Belgium
    It probably is, yes. Try to find a better grounding point. Best is to make one yourself, that has a greater surface.....
    Xenia & Isabelle, totally in love!
    'T SQiekenkot: VOLVO 740GL 2.3
    CarPC: none at the moment
    CLARION HX-D2
    CLARION APA4300HX => Fountek NeoCd1.0 + TB W4-1337SD
    CLARION APA4300HX => CSS Trio8
    CLARION APA2100 => Dayton IB385-8
    Mar 2007
    hmm how do i do that sorry little noobish here
    I can screw a plate down from the boot the main body of the car and earth it to that as that what i have my power cap earthed to as i have screw my sub and everythink down in the boot
    Jun 2006
    Abele, Belgium
    won't be much better. the earthing point has to be as small as possible, but has to have a surface as big as possible. So the best you could do is bolt it down through body of your car.
    CLARION HX-D2
    Mar 2007
    hmm i have nooo idea
    the screw are big there steal screw if i just script the earth wire strate down would that be better
    Jun 2006
    Abele, Belgium
    you'll have to try. You could drill a hole through the bottum of your trunk at 1 place and put your ground on. But it's very well possible, if you'd drilled a hole 1" away from that, you would've had a bad ground. The most important is to make the ground as solid as possible, scraping/sanding off all the pant and dirt.
    CLARION HX-D2
    Mar 2007
    ok i will have a play
    so u think that what the poping is..
    what if the cable is not think enought or somthink
    Jun 2006
    Abele, Belgium
    A cable that isn't thick enough will bring up other flaws. The fact that you have a pop when you turn on your wiper, is because you're getting undirected power through your wires. I don't know if you've ever been in an old house with bad worn electrical wiring... If you have, you certainly will have noticed lights dimming when you turne on the tv or something. That's be cause it gets a short electrical pulse. And my guess is that you're experiencing the same here.
    CLARION HX-D2
    Mar 2007
    What if i earth it strate to the battry
    or just make a better point
    Jun 2006
    Abele, Belgium
    just make better point. The earth needs to be as short as possible!
    CLARION HX-D2
  1. Noise on audio from laptop
    By pip in forum Laptops, Netbooks, Tablets, UMPCs, etc.
    Last Post: 11-24-2006, 08:09 PM
  2. SXRC.... Engine Noise Problem
    By bird in forum Car Audio
    Last Post: 05-30-2006, 01:21 AM
  3. Noise coming through speakers - Help Needed
    By tbird2340 in forum Car Audio
    Last Post: 09-27-2004, 04:31 PM
  4. Noise!! AARGH!
    By sq_geek in forum General Hardware Discussion
    Last Post: 09-21-2004, 02:33 PM
  5. Damn Noise
    By Freeman in forum General Hardware Discussion
    Last Post: 03-20-2004, 01:37 AM
