Results 1 to 10 of 12
Thread: Newbie with connection conundrum (again)
    Mar 2007
    Sorry if you have seen this post before, a moderator deleted it by accident and it hasn't reappeared yet, so here goes
    Need to connect pc to standard Tevion head unit. No inputs, amplifier out.
    CD, SD and usb in (takes mass storage device, don't know max capacity)
    Is there any way of using the usb port as a line in. I am planning on replacing the head unit eventually as soon as one comes up. I have a small fm transmitter as a last resort.
    Any ideas greatly appreciated
    Current setup is laptop pc ad media engine, motorised dash screen. Want to build a voompc into the floor of a citroen berlingo
    Mar 2006
    Colorado, but Canadian!
    Quote Originally Posted by dcmarsh View Post
    usually no you cannot use the USB in as a line in unless that feature is explicitly defined as a feature. There are some that are able to do this, but they are expensive. My guess is no.
    Don't you have any aux in or anything? Maybe a wired direct connect FM modulator would be better as a last resort because it will be as clear as a never going away FM station...
    1.9in x 2.9in -- 47mm x 73mm
    Mar 2007
    Nope, no auxillary's at all
    nope, there's no auxillary inputs whatsoever. Unit was a cheapie one.
    Bummer though, really didn't want to have to add a modulator as I'd have to find yet another 12v line to use.
    May just have to use transmitter for the time being.
    Any idea's if they can be hacked ala camcorder firewire dv in/out
    any other idea's? Don't want to fork out yet until the pc is built/in.
    voompc - 2gb compact flash/ewf/horm/12 sec startup whoooo
    at least that's what I'm getting from the laptop, 1gb of RAM helps!
    Mar 2006
    get a different cheapie. Really. You can get cheap units with inputs for like $40.
    FLAC XC-C30's Avatar
    Jun 2006
    Abele, Belgium
    No cd-changer input even?
    Xenia & Isabelle, totally in love!
    'T SQiekenkot: VOLVO 740GL 2.3
    CarPC: none at the moment
    CLARION HX-D2
    CLARION APA4300HX => Fountek NeoCd1.0 + TB W4-1337SD
    CLARION APA4300HX => CSS Trio8
    CLARION APA2100 => Dayton IB385-8
    Mar 2007
    Quote Originally Posted by 2k1Toaster View Post
    I'm in the UK, Where? I want one
    best I can find with mp3 support is 50 ($100 ish) and they only come up really rarely
    for uk buyers, Aldi and Netto's are the (slightly odd) places to look but they only come up occasionally).
    No, no cd changer inputs.
    Mar 2006
    why do you need mp3 support?! That is what the computer does. And $40 is for something from a local shop. So I figured cheaper on ebay. After I get off work, I will find one....
    Jun 2006
    Abele, Belgium
    http://cgi.ebay.fr/AUTORADIO-TEVION-...QQcmdZViewItem
    This is what I found on the HU, and it has cd-changer input. So it's probably possible to convert that to an auxiliary input.
    edit: 2k1, it's in french, so maybe you could translate? (my french isn't good enough for that)
    CLARION HX-D2
    Constant Bitrate mwmcginn's Avatar
    Dec 2006
    St Louis
    +1 on finding something new. If you can afford the CAR PC install, you should at least support it with something for now. If you cant, use the MF modulator until it drives you crazy and you buy a better unit.
    Mike M
    2006 Accord VP Sedan
    My worklog
    http://www.mp3car.com/vbulletin/work...-dads-car.html
    Low Bitrate dontpntpool's Avatar
    Aug 2006
    IA
    use the fm transmitter for now... don't waste money if you can already make it work... since you know you will be upgrading soon it doesn't really matter.
    just wait...
  1. WIFI CONNECTION MANAGERS (mini review)
    By liquid_smoke in forum Software & Software Development
    Last Post: 04-27-2007, 09:04 PM
  2. EDGE connection on WM5 phone for Inet access...
    By kristiandg in forum StreetDeck
    Last Post: 12-01-2006, 05:43 PM
  3. Replies: 56
    Last Post: 06-09-2006, 05:43 AM
  4. External Apps & DUN connection question
    By DarquePervert in forum StreetDeck
    Last Post: 05-27-2006, 12:54 PM
