The easiest way to test it is by connecting the remote wire to the same power source/connection as what's been used for the continuous supply.
Hello i have a brand new Infinity Reference 7541a 4 Channel Amp that is not powering up. This is the first attempt i have given to hook up this amp and to my dismay, its not going very well. I have routed all off my wires (ground, power and remote) yet once i connected the 12v line from my battery to my amp the powerlight did not go on.
I then installed a voltage/amperage monitor in the 12v line and it picked up voltage readings so i know the line is live. I used the amp ground line to ground the v/a monitor so i know the ground is good. The only question i have is the remote wire but i ran a wire directly from the remote radio line to the remote input on the amp so i dont see where i could have gone wrong here.
My question is if the known live 12v line going to the amp is connected, should the power led on the amp light up? There are 3 LEDs on the amp, (power, protect, and clip) and none of them light up. Would an improper remote line prevent the power led from lighting up? When i connected the 12v line a seconed time to the amp the recheck the connection it sparked a little. All fuses and lines are good to the best of my knowlege, Could this amp be bad or could it be my remote? thanks
EPIA Nehemiah M10k, M1-ATX, 20GB 4200 RPM 2.5", 256MB RAM, Win XP Home, Gyration RF Keyboard & Mouse, Zoltrix Nightingale Optical 4.1 PCI Sound Card, Lilliput 619GL-70NP, XM-PCR w/ optical upgrade, Garmin GPS-25LVS, Microsoft MN-710 USB Wireless NIC
So you say to connect the ground wire leaving the amp to the 12v line entering the amp? And this will tell me if the amp is good or not? Sorry for the ignorance and thanks for the help.
NO...! That's NOT what I've suggested. Leave the ground wire alone. You should NEVER connect ground to any positive connection. That is a #1 recipe for disaster. NEVER do that.
You said that the amp has three connections: power, remote, and ground. The "Power" connector or post should be connected to a continuous 12V (positive) power source.
Remote should be connected to a switch power source so the amp only turns on when the sound source is turned on. For testing purpose, you could use the same power source you've connected to the "Power" connector or post.
Ground should be connected to a metal surface on your vehicle.
Again, NEVER connect ground to anything positive. NEVER..!
Xenia & Isabelle, totally in love!
'T SQiekenkot: VOLVO 740GL 2.3
CarPC: none at the moment
CLARION HX-D2
CLARION APA4300HX => Fountek NeoCd1.0 + TB W4-1337SD
CLARION APA4300HX => CSS Trio8
CLARION APA2100 => Dayton IB385-8
lol, sorry for mis interpreting that. I will connect the remote wire to the 12v power wire running from the battery and post back to report on my findings. thank you.
a DMM is very handy to any DIY'er![]()
DAMN, I could go for a nice grilled steak right now. Too bad you didn't short your amp. Would've been a nice fire....![]()
Just joking
CLARION HX-D2
WOW THANK YOU. This trick turned my amp on. THank god it isnt blown. Now i just need to find out which wire i can connect my remote line to turn the amp on. I drive an Acura Legend 1994 GS Sedan and have been searching the www.acura-legend.com forums for a suitable remote amp hookup, my search continues. thank you all very much.
you'd want to hook it up to the IGN line in your standard wiringharness.
CLARION HX-D2
