Page 3 of 3 FirstFirst 123
Results 21 to 25 of 25
Thread: Episode 2
  1. #21
    And then I was mod. Tidder's Avatar
    Sep 2003
    New Mexico, USA
    Man, someone should have corrected me. I hate sounding like an idiot...
    Sent from my DROID2 using Tapatalk
    Tidder
    Try RevFE
  2. #22
    fka - Nextabyte_Matt ioi8's Avatar
    Apr 2006
    Cleveland
    Quote Originally Posted by Tidder View Post
    Dont worry, quite used to it now.
    So I am searching about this latency issue. When I mean latency, I mean the total time from when the app needs the data, cpu requests it, goes over the memory bus to the dimm, and returns with the data. The CAS latency you brought up before is only the time it takes for a single module on dimm to return data.
    However, the timings that you find on memory is only for the single modules themselves, not for the entire dimm. These modules are controlled by the memory controller. If the memory controller needs to handle more of these modules (many 2GB and 4GB memory dimms are double-sided), then the locate to read/write ops should take longer.
    However, even though memory latencies may increase slightly (I retract my statement of double), it seems that somehow windows xp is still able to increase performance with more memory. http://www.pcauthority.com.au/Featur...ifference.aspx
    I think what we need someone to do is use windows xp and use everest and record 1GB and 2GB memory latency times.
  3. #23
    Jan 2008
    but because some of the latency is caused by the memory controller, wouldn't a single motherboard test of 1gb, and 2gb only show that boards latency? is that good enough to judge other similar motherboards on?
  4. #24
    Jan 2008
    so did the podcast die?
  5. #25
    licensed to kill - FKA kev000
    tripzero's Avatar
    Aug 2006
    16.40618, 120.61106
    Quote Originally Posted by soundman98 View Post
    We actually did episode 3, but a recording blunder killed it. We are trying to regroup for another run.
    Former author of LinuxICE, nghost, nobdy.
    Current author of Automotive Message Broker (AMB).
    Works on Tizen IVI. Does not represent anyone or anything but himself.
  1. Episode 1
    By tripzero in forum Carbytes podcast
    Last Post: 10-28-2010, 05:52 PM
  2. Where to get Media Center 2005?
    By PhatzPerformanc in forum XP MCE
    Last Post: 12-30-2005, 02:03 PM
  3. Geek My Ride - Episode 1
    By GB Vette in forum Fabrication
    Last Post: 12-23-2005, 12:50 PM
  4. Episode III: the saga is compl33t
    By zPilott in forum Off Topic
    Last Post: 04-13-2005, 11:03 AM
  5. Episode II humor
    By Machs_FueL in forum Off Topic
    Last Post: 05-29-2002, 09:26 AM
