Results 1 to 10 of 14
Thread: removing warning massage
    May 2005
    Hi guys how do i remove the warning massage when i start CentraFuse ?
    thanks alot.
    Raw Wave Laidback's Avatar
    Oct 2003
    Madrid
    Cf even gives you a massage? Wow, what next! ;-)
    VENDOR - Centrafuse veetid's Avatar
    Quote Originally Posted by russian_mafia View Post
    thanks alot.
    check out under the Important Notes number 4 in the 1.1 release notes below...
    It shows how to add parameters... Look at New Features numbers 14 and 15 for descriptions of the parameters...
    Centrafuse 1.1 Release Notes
    there is a current issue when setting run as shell, but this has been fixed in the upcoming release...
    david
    May 2005
    thanks i got it. Man this software Rock man, i just wonbder if they gonna do the online radio plug-in ?
    Variable Bitrate m2x0p9x's Avatar
    May 2002
    Modesto, CA
    So whats wrong with running it as shell? Will centrafuse run ok? How are we suppose to use the -nowarning and -nolimit when running as shell?
    May 2005
    well i tried using it in shell but it here is massages comming from my powermate that its connected and then its say disconnected
    May 2006
    Seattleish, WA
    Quote Originally Posted by m2x0p9x View Post
    David will fix this so it's automatic, but for now, you'll need to edit the registry manually to get the params in there.
    :: Mark
    May 2005
    and how you do that, cuz the warning massage comes in shell ?
    May 2002
    Modesto, CA
    yea i was wondering also where to input the params...i need to run cf as a shell...when is the next release coming out?
    May 2006
    Seattleish, WA
    I thought David outlined it in a thread here, but I couldn't find it. I also looked on the FluxMedia site but... couldn't find it there either. I know I've seen someone talking about it... hmmm...
    Anyway, if no one beats me to it, I'll set it up and do a walk-through a bit later this morning...
    :: Mark
  1. Invalid Argument
    By tn6478 in forum StreetDeck
    Last Post: 12-30-2007, 09:02 PM
  2. iGuidance Full Screen & Device Warning
    By zzzBrett in forum GPS
    Last Post: 02-17-2007, 12:12 AM
  3. IRMAN plugin
    By knyarko in forum StreetDeck
    Last Post: 01-05-2007, 09:26 PM
  4. Girder HID Plugin
    By Kalt in forum StreetDeck
    Last Post: 07-04-2006, 01:14 AM
  5. 1.0.4.7 bug
    By debugger in forum StreetDeck
    Last Post: 07-01-2006, 04:01 AM
