Skinbedder will remain running as long as the embedded app (iGuidance in your case) is running.
The way it works, I believe, is that as soon as your embedded app (iG) quits, then SkinBedder will also quit running. You don't close Skinbedder, you close the embedded app... that's what should trigger sb to close.
If I recall correctly, attempting to manually close SB will make things go awry.... but I might be wrong.
LinkBack URL
About LinkBacks
