Results 1 to 10 of 12
Thread: Speed Camera Addon With Sounds!
    Oct 2006
    Exclamation Speed Camera Addon With Sounds!
    Use the importer built in to centrafuse to impirt the .csv file of your speed camera list to newly created folder, then one all is imported click anywhere on the actual map of the navigation and select favorites, once you have selected this click back on the menu which pops up and next to the folder to where you imported the spee cams slect the closed eye picure which now becomes open, continue with ok, and you will now have a speech `favourites alert` everytime you approach a camera, install the attatched as appropriate and you now have speed warning instead as ths speech warning...
    note: Extract The Dowload directly to your centrafuse directory and whalla! speed detection now has sound!
    hope this clears it all up and give all a temporary fix until it is implimented in davids latest releases
    Thankyou
    Attached Files Attached Files
    Newbie White 'van' Man's Avatar
    Jun 2006
    No Favorites on map ?
    I tried this a while back... but when i click on the map
    all i get is a window with "Navigate" "Recalculate" & "Set As Origin" no favorites !!! what am i doing wrong....
    I can inport the locations & they all appear in the favorites list but i cant get them to display....
    And to cap it all off i just got a summons for 88mph an the A38...
    Speed cameras... I pizz on em !
    CF 1.11 Destinator 6 maps (2006.Q1.4156)
    Any Ideas ???
    Steve
    Oct 2006
    help, maybe?
    I found i had this exact same problem in my car pc but the install on my pc was working fine, only difference between the two was one was unregistered and the other was! so i simply deleted the licence file in my car and ran it under trial condition with favorites once i had changed the eye to open i then re registed and hey presto speed alerts, although still very glitchy in some locations! really really need david to fix this problem and put a official addon to centrafuse
    thankyou
    VENDOR - Centrafuse veetid's Avatar
    working on it...
    david
    Mar 2007
    South Australia
    hey thanks for this solution, worked great in version 1, and in version 1.1 we could still use it by using the solution from this page http://www.mp3car.com/vbulletin/cent...ites-gone.html but what about for centrafuse 1.12? any ideas
    FLAC ShawJohn's Avatar
    Aug 2004
    On the edge!
    set your cams and favorites up in 1.0 and then copy the folder to the new CF1.12.
    Mine still work
    Mar 2007
    South Australia
    ok so i can copy the favorites files across (as in the dat file and its picture file), that works but they no longer show on the map, the show up in favorites menu as in if i wanted to navigate to the nearest camera. am i doing something wrong, i really want them do show on my map.
    Aug 2004
    On the edge!
    go into the poi list in CF and click each favorite until the eye is displayed next to it, that turns the map POI icons on...
    Mar 2007
    South Australia
    i have added my red light cameras into my favorites as i can not add them into point of interest, centrafuse gives error "canot add to current list. therefore as they are in my favorites i can not click the "show" button to make the eye appear.
    Mar 2007
    South Australia
    any help guys... i have the latest version 1.13 and still cant get my red light camera displayed on the map
  1. RELEASE: Map Monkey v1.1.3
    By Ninja Monkey in forum Map Monkey
    Last Post: 02-12-2009, 11:27 AM
  2. GATSO Hunter speed camera error
    By zeroasylum in forum Software & Software Development
    Last Post: 12-07-2006, 12:43 PM
  3. Structure of speed camera file
    By pijo1971 in forum Map Monkey
    Last Post: 10-27-2005, 03:39 AM
  4. Speed Camera Updates in MapMonkey
    By M pro in forum GPS
    Last Post: 05-18-2005, 08:19 AM
  5. Speed Camera FAQ ?
    By ccsnet in forum Map Monkey
    Last Post: 12-29-2004, 05:14 AM
