Results 1 to 5 of 5
Thread: Creating Playlists + Sync Music automatically
    Aug 2004
    Bundaberg QLD AU
    Is is possible to create playlists on my desktop then transfer them to my carputer?
    Also is there anyway to make my carputer automatically sync music by WiFi with my desktop pc?
    Dec 2006
    if you use the same directory structure for your music, playlists should be transeferable
    so, if you store your music on c:\music on your home pc and create a playlist, the playlist looks for that music on c:\music
    if your music is stored on your car pc on c:\music aswell in the same folders and subfolders as on your home pc (i.e. if you just copied the entire c:\music from home to car pc then the playlist will work as the files are in the same place
    i.e. file one would be c:\music\coldplay\yellow.mp3 in the list
    as long as your yellow.mp3 is in that localtion it will work if it was somewhere else then it wouldnt
    hope that makes sense
    Raw Wave justintime's Avatar
    Apr 2005
    Search for utility called EZSync
    2002 Honda CR-V
    Spent so far: $1105.90
    ...or even Listen to my music
    Aug 2004
    Bundaberg QLD AU
    Ok I can write a program that creates the PlayLists to point at the right path (different drives, different folder on drive, but same directory structure)
    OK What format does the playlist need to be in? and how do i open a playlist?
    VENDOR - Centrafuse veetid's Avatar
    The playlists are just text files in the Playlist folder...
    Also on the flux forums in the plugins section there is a nice Sync plugin that has been made...
    david
  1. Playlist Converter Released for RR
    By SangreDeThor in forum Road Runner
    Last Post: 02-21-2009, 01:19 AM
  2. Creating Playlists for ME outside of ME
    By greenglo in forum Media Engine
    Last Post: 05-15-2004, 07:40 PM
  3. Creating playlists....
    By UrbanDragon in forum Media Engine
    Last Post: 04-15-2004, 01:54 PM
  4. creating and updating playlists
    By kami333 in forum MediaCar
    Last Post: 01-23-2004, 03:53 PM
  5. Replies: 11
    Last Post: 10-16-2001, 09:50 AM
