Results 21 to 30 of 31
Thread: Infill G4 Centrafuse install
  1. #21
    Feb 2005
    OK
    I downloaded cf1.20 and installed over an old cf install on my infill G4
    I was asked to reboot
    then
    Installed the "Infill installer" as per Dave's instructions on the previous post
    Clicked on the exe on the desctop and then on "try" for the licence
    it took me through the setup
    on the last page I click on "save" I confirm the "overwrite" and then........nothing happens
    The only other choice is "cancel" if I click on that CF exits
    I checked the installation files against the "cfinfill" manual install file and the installation seems to be ok
    Im excited to try this version!
    What gives?
    Testing Street Deck and Centrafuse on G4
  2. #22
    VENDOR - Centrafuse veetid's Avatar
    no need to have reinstalled... there was an issue with 1.20 that caused the database to corrupt, this does not seem like an Infill issue...
    try to uninstall all plugins and Centrafuse, then manually delete your Centrafuse folder...
    Then install and setup Centrafuse... once Centrafuse is setup and running properly, then install the CFInfill plugin and it should work...
    The 1.40 update will be out soon which fixes many issues found in 1.20, hopefully tomorrow...
    david
  3. #23
    Feb 2005
    Quote Originally Posted by veetid View Post
    david
    Ok David
    Ill try to do it tonight, and if not, I ll wait for the update
    BTW its refreshing to get a reply within a few minutes for a product that I havent even bought yet
    I will definitely buy it. even if only to show my support!
  4. #24
    Feb 2005
    Im using an HTC Kaiser phone
    it has an "internet connection sharing" setting that automatically allows the computer its connected to, (usb or bluetooth) access to the internet through its connection
    CF asks for a dial up connection, in order to configure internet access is there a workaround?
    BTW i can go online using a browser outside of CF
  5. #25
    Low Bitrate marci's Avatar
    Jul 2007
    Switzerland
    Hi Spiro, if you use the ICS feature of the kaiser, you have a second LAN connection. (or the first, if you not have another LAN) That works only if you have installed Active Sync 4.5 (always required for WM6 Devices) and - i think - a membership with active sync.
    in the Internet connection settings there must be set the setting use LAN. (I think that is by default)
    maybe - if you need a DUN (dial Up conenction) use the old modem driver of the HTC Tytn.
    than you must set your own network provider APN into the network settings. have a look to the forum of http://xda-developers.com, there you can find all what you need.
    but i think, CF can use an existing LAn connection to bring you up to Inet?
  6. #26
    Feb 2005
    Bluetooth
    Thanks Marci
    I was able to get it to work just like you said and im trying to make it work with bluetooth now
  7. #27
    Feb 2005
    Infill radio doesnt work!
    I didnt bring this up before, because I was solving other issues but I was never able to get the radio working on the G4 with the G4 plugin
    The dll is there and its configured correctly on the settings screen with "line" input enabled but when the radio application opens I dont hear anything
    PS if I click on the (!) I get a message "no radio info available" or something like that, so I dont think CF knows which radio to use
    How about gestures? are they supposed to be in CF1.20 or as an add on?
    I read mentions of CF v1.30 but I dont know how to get my hands on it
    Also when I install the belkin bt dongle for phoco, which drivers do I install?
    is there an installation manuall? I tried phoco's website and its beem down intermittently, and some links dont work!
    Finally I have come across a very nice free tool which I use with my home theater PC, it solves stand by and usb issues, I think it can be used on the G4 to solve the bt wake up issues (havent tried it yet)
    here is the link http://www.xs4all.nl/~hveijk/mst/indexe.htm
  8. #28
    Jul 2007
    Switzerland
    H Spiro:
    about G4 and Radio:
    do you read that?
    http://forums.fluxmedia.net/showthre...ht=improvement
    (I use CF1.30 and the plugins, for radio, maybe it works with 1.20 too?)
    What I See too, you habe to Line In regulators in your audio System configuration. one for playback, and one for recording. Is one of that wrong and not muted than itīs not work. sometimes i play with the wrong regulator, no radio playback works through i start G4 new. (start over)
    For bluetooth with Phonecontrol:
    the best features you have, when you install the latest Widcomm / broadcom drivers.
    When you have luck, then is with your USB Stick this drivers included. the best version is 5.0.18 (i think) with the standard Bluetooth (that comes with Microsoft XP) you can use only minimal features of PhoneControl.
    Thank you for your link with the USB hibernation Problem.
    thats a another good way:
    http://www.mp3car.com/vbulletin/faq-...de-devcon.html
  9. #29
    Feb 2005
    Quote Originally Posted by marci View Post
    H Spiro:
    about G4 and Radio:
    do you read that?
    I enabled (un-muted) the line input on the sound card and the radio works but, how do I make CF control that?
    I have to go into the sound settings every time I want to stop the radio or listen to something else.
    Also please take note of this thread I just posted
    rear camera capture utility
  10. #30
    Quote Originally Posted by spiro View Post
    this has been fixed and added directly in 1.40 which will hopefully be out today...
    david
  1. MP3Car Infill G4 install in a 2003 Infiniti G35
    By god_of_cpu in forum Mp3Car Infill G4 - Double Din Car Computer
    Last Post: 10-24-2008, 07:44 PM
  2. New Release Centrafuse 1.20
    By veetid in forum Centrafuse
    Last Post: 10-10-2007, 08:12 PM
  3. MP3Car Infill G4 install in a 2004 Volkswagen Jetta
    By Zip-Lock in forum Mp3Car Infill G4 - Double Din Car Computer
    Last Post: 04-17-2007, 08:51 AM
  4. Replies: 22
    Last Post: 04-15-2007, 10:38 PM
  5. G4 or Intel Mac Mini for new install?
    By guitartech in forum MacCar
    Last Post: 02-05-2007, 08:29 PM
