Page 1 of 4 1234 LastLast
Results 1 to 10 of 31
Thread: Infill G4 Centrafuse install
    Oct 2004
    Hi,
    I've installed Centrafuse on my Infill G4. But the FM radio isn't working.
    The FM radio is working ok with the infill front end software.
    So I think it's a driver issue.
    Any ideas ???
    Michel
    Apr 2005
    Queens, New York
    I dont think its a driver issue but more of a software compatibility issue...
    2002 Mitsubishi Galant
    Carputer Specs:
    Via M10K
    512mb Ram
    60GB HDD
    Souund Blaster Audigy2 NX
    OPUS ITX PC Case
    Oct 2004
    infill g4
    I think the two are the same. But thats a other discussion.
    Did anybody get the FM radio working in centrafuse ?
    Even better where are the Infill G4 radio drivers ? I have the drivers but don't see any radio driver. The Radio is working good with the infill frontend software. So there must be a driver installed...
    Can a developer from Centrafuse answer this ??????
    michel
    VENDOR - Centrafuse veetid's Avatar
    a CF radio module will need to be created for the Infill G4 radio hardware...
    If they have a development object for their radio hardware it would not be hard, or atleast some specifications...
    I will contact them after the upcoming release to get details...
    david
    Oct 2004
    David,
    Thanks!
    I can send you the radio (.dll files) drivers. Or you can download all drivers for the G4 system on:
    http://www.cartft.com/support/driver...rivers/infill/
    But I don't know what HW component it is.
    I'am willing to test your drivers if you want ..
    Michel
    Dec 2006
    any luck getting the infill g4 gps to work on centrafuse? what setting did you use?
    Oct 2004
    The GPS is working out of the box. No problem at all.
    But NO TMC ans its 9600bps. But it is OK.
    Michel
    Dec 2006
    yeah i got it to work now. Same issue with radio. Any trick for the radio that you have recently figured out?
    Oct 2004
    Then I start up centrafuse and minimise it. Then I startup the infill radio and select the radio channel. I've setup a fake radio in the centrafuse setup. So when you press radio in centrafuse the radio audio from the infill radio will be given. And if you choose mp3 music the radio line is muted.
    Because the G4 unit is always on you have only to do this setup/sartup once.
    P.s Did you have setup the bluetooth car kit succesfully ? I'm getting a dot net error when i start up the phonecontrol setup wizard.
    Sep 2006
    Sydney
    good idea..
    Ill have to do that. I only listen to 1 radio station anyway.
  1. MP3Car Infill G4 install in a 2003 Infiniti G35
    By god_of_cpu in forum Mp3Car Infill G4 - Double Din Car Computer
    Last Post: 10-24-2008, 07:44 PM
  2. New Release Centrafuse 1.20
    By veetid in forum Centrafuse
    Last Post: 10-10-2007, 08:12 PM
  3. MP3Car Infill G4 install in a 2004 Volkswagen Jetta
    By Zip-Lock in forum Mp3Car Infill G4 - Double Din Car Computer
    Last Post: 04-17-2007, 08:51 AM
  4. Replies: 22
    Last Post: 04-15-2007, 10:38 PM
  5. G4 or Intel Mac Mini for new install?
    By guitartech in forum MacCar
    Last Post: 02-05-2007, 08:29 PM
