Page 3 of 3 FirstFirst 123
Results 21 to 25 of 25
Thread: MappPoint 2006 "not available" error
  1. #21
    VENDOR - Centrafuse veetid's Avatar
    It is in C#
    david
  2. #22
    May 2006
    Seattleish, WA
    'k... I'm in the code and have some questions. Would you rather I ask them on the Flux forum?
    The first one's pretty basic - the project doesn't build right out of the box.
    :: Mark
  3. #23
    Quote Originally Posted by midiwall View Post
    this has to be a simple reference issue and possibly a build location...
    the code does compile, I opened it yesterday to fix the map detection issue...
    you might wait until I get this update finished and post the new code that works without having both NA and Europe installed...
    david
  4. #24
    May 2006
    Seattleish, WA
    Cool.. I'm sure it's a reference issue of somesort. VisStud is complaining about not being able to find the namespaces:
    Code:
    C:\WINDOWS\Microsoft.NET\Framework\v2.0.50727\Microsoft.Common.targets : warning MSB3287: Cannot load type library for reference "AxMapPoint". Library not registered. (Exception from HRESULT: 0x8002801D (TYPE_E_LIBNOTREGISTERED))
    C:\WINDOWS\Microsoft.NET\Framework\v2.0.50727\Microsoft.Common.targets : warning MSB3287: Cannot load type library for reference "MapPoint". Library not registered. (Exception from HRESULT: 0x8002801D (TYPE_E_LIBNOTREGISTERED))
    c:\WINDOWS\Microsoft.NET\Framework\v2.0.50727\Csc.exe /noconfig /unsafe- /checked- /nowarn:1701,1702 /nostdlib- /errorreport:prompt /warn:4 /baseaddress:285212672 /define:TRACE /reference:"C:\projects\Centrafuse SDK 1.12\Examples\Plugins\MapPoint\GPSUtilities\bin\Release\GPSUtilities.dll" /reference:c:\WINDOWS\Microsoft.NET\Framework\v2.0.50727\System.Data.dll /reference:c:\WINDOWS\Microsoft.NET\Framework\v2.0.50727\System.dll /reference:c:\WINDOWS\Microsoft.NET\Framework\v2.0.50727\System.Drawing.dll /reference:c:\WINDOWS\Microsoft.NET\Framework\v2.0.50727\System.Web.dll /reference:c:\WINDOWS\Microsoft.NET\Framework\v2.0.50727\System.Windows.Forms.dll /reference:c:\WINDOWS\Microsoft.NET\Framework\v2.0.50727\System.Xml.dll /debug- /filealign:4096 /optimize+ /out:obj\Release\MapPoint.dll /resource:obj\Release\CFMapPoint.CFMapPoint.resources /target:library /warnaserror- AsyncWebDownload\Download.cs AsyncWebDownload\Progress.cs MapPoint.cs MapPointUtils.cs menudialog.cs viewdialog.cs
    C:\projects\Centrafuse SDK 1.12\Examples\Plugins\MapPoint\viewdialog.cs(5,7): error CS0246: The type or namespace name 'centrafuse' could not be found (are you missing a using directive or an assembly reference?)
    C:\projects\Centrafuse SDK 1.12\Examples\Plugins\MapPoint\viewdialog.cs(9,28): error CS0246: The type or namespace name 'CFDialog' could not be found (are you missing a using directive or an assembly reference?)
    C:\projects\Centrafuse SDK 1.12\Examples\Plugins\MapPoint\AsyncWebDownload\Download.cs(6,7): error CS0246: The type or namespace name 'centrafuse' could not be found (are you missing a using directive or an assembly reference?)
    C:\projects\Centrafuse SDK 1.12\Examples\Plugins\MapPoint\menudialog.cs(8,7): error CS0246: The type or namespace name 'centrafuse' could not be found (are you missing a using directive or an assembly reference?)
    C:\projects\Centrafuse SDK 1.12\Examples\Plugins\MapPoint\menudialog.cs(9,7): error CS0246: The type or namespace name 'centrafuse' could not be found (are you missing a using directive or an assembly reference?)
    C:\projects\Centrafuse SDK 1.12\Examples\Plugins\MapPoint\menudialog.cs(13,28): error CS0246: The type or namespace name 'CFDialog' could not be found (are you missing a using directive or an assembly reference?)
    C:\projects\Centrafuse SDK 1.12\Examples\Plugins\MapPoint\MapPointUtils.cs(13,7): error CS0246: The type or namespace name 'centrafuse' could not be found (are you missing a using directive or an assembly reference?)
    C:\projects\Centrafuse SDK 1.12\Examples\Plugins\MapPoint\MapPoint.cs(13,7): error CS0246: The type or namespace name 'MapPoint' could not be found (are you missing a using directive or an assembly reference?)
    ... There's a total of 55 of 'em...
    I'll wait for the update. Thanks David.
    :: Mark
  5. #25
    You just have to add a reference to the MapPoint 2006 object, also possibly remove and re-add the cfplugin reference...
    You should expand the references and you will see some exclamation points where the reference is bad... Remove each one and right-click and add reference to add them back...
    to add MapPoint 2006 you will see it in the reference list if it is installed... For cfplugin just browse to the location of cfplugin.dll from the SDK...
    david
  1. Headunit (Linux/Windows CarPC frontend) + initial screenshots
    By NoPistonPC in forum Other Cool Front Ends
    Last Post: 08-24-2007, 02:57 PM
  2. Replies: 7
    Last Post: 07-01-2005, 03:29 PM
  3. ME 2.0 Official Bug Reports
    By phat_bastard in forum ME Archive
    Last Post: 01-31-2004, 06:27 PM
  4. Error #91
    By SiGmA_X in forum ME Archive
    Last Post: 01-08-2004, 09:40 PM
