Results 1 to 5 of 5
Thread: cf/iguidance no gps signal
    Newbie BlacOrkhiD's Avatar
    Feb 2007
    bx, nyc
    i have my gpslim 236 connected via bluetooth ( it wont connect to a signal via usb serial) i get a signal in my gpsveiwer but not in cf or iguidance. i checked to make sure the com ports are the same still not working. what am i missing?
    Aug 2006
    i had the same problem... go into the destinator gps settings. Mine said no port but iguidance still wasn't working when embedded. Just change that to something you know iguidance isn't using with your gps. I put com4... after that I had no problems.
    Feb 2007
    bx, nyc
    that sounds logical but im not sure how to get to the destinator gps settings.
    i changed the navi com setting in cf, still didnt work. then i tried to open destinator from the cf folder in program files but it doesnt show any setting when opened. just a berlin map.
    VENDOR - Centrafuse veetid's Avatar
    Go to navigation settings and set the navigation engine to None, this will make it not load at all
    david
    Feb 2007
    bx, nyc
    Quote Originally Posted by veetid View Post
    david
    tried that too still no signal. another thing that happends when i set the gps bluetooth in bluesoleil it connect no problem. i then load cf, open cfig there is no signal. i'll then close cf to find that bluesoleil has closed then i have to reload it again.
  1. Replies: 91
    Last Post: 11-07-2006, 05:47 PM
  2. using OEM GPS signal for carpc
    By met152 in forum GPS
    Last Post: 11-01-2006, 07:34 AM
  3. Newbie's guide
    By EBFoxbat in forum Newbie
    Last Post: 02-08-2005, 11:06 AM
