Results 1 to 10 of 12
Thread: Anyone recommend a good USB GPS with external antenna output?
    Low Bitrate ccrobin's Avatar
    Apr 2005
    Hello all. I have a bluetooth GPS right now that I am using with CF, but I seem to lose connection from time to time. I am looking for a good USB antenna that I can use and bury in my glove compartment (as I have an external antenna lead terminating in there), but most USB GPS pucks I have seen do not have an external antenna connector.
    Any suggestions would be greatly appreciated!
    Mar 2006
    Colorado, but Canadian!
    Well just a regular usb wired gps puck like the bu-353 can be placed in the dash behind metal and plastic, and still receive a strong signal.
    I just recently (4 days ago) bought a BU-353 and I shoved it in my dash behind metal and plastic. I got a ton of satellites and a quick lock from it. Even in my garage with the door closed I can still pick up a good signal.
    So an external antenna really isnt neccessary.
    If you are really wanting to use an external antenna, then you could get a oem chip (like from sparkfun) and connect it that way. They even have a 5hz chip to buy.
    1.9in x 2.9in -- 47mm x 73mm
    Raw Wave justintime's Avatar
    Apr 2005
    Get a SIRF4 capable unit. They will lock even indoors, sometimes. Definitely no need for an antenna unit nowadays!
    2002 Honda CR-V
    Spent so far: $1105.90
    ...or even Listen to my music
    Apr 2005
    Wow! Cool. Thanks for the info. I didn't realize the newer GPS pucks were so good.
    Apr 2005
    Quote Originally Posted by justintime View Post
    I have been looking and do not see any unit boasting SiRF4 capabilities. I can't even find any reference to SiRF4 on SiRF Technologies website. Are you sure you do not mean a SiRF3 compatible unit?
    I see dead kittens Quattro's Avatar
    Dec 2003
    New York
    I'm pretty sure he meant SiRF3, because I myself haven't seen any SiRF4 units.
    Installed
    Asus A7N8X-VM - AMD Mobile Athlon 2400
    512 Ram - 60GB HD - Opus 150w
    Lilliput 7" - Rikaline 6010
    [00000000000001100010-] 98% Completed
    Check Out My Install!!!
    May 2007
    You need to add your location and vehicle
    I am in NH (far away from the equator satellites, and with many trees). I have a pickup truck with a slideone camper. I can only get GPS and Satellite Radio signals when I am Southbound. Once I turn any other direction the camper blocks all the signals.
    I am looking for two GPS antennas. When the camper is installed, the one on the camper roof will be plugged in. Otherwise, the one on the truck roof would be plugged in.
    Carl in NH
    Mar 2006
    Quote Originally Posted by diyer View Post
    Carl in NH
    If you get just a regular SirfIII GPS receiver and stick it on the top of your camper, it will work just fine. I have used my Sirf2 GPS as far north as Thunder Bay, Ontario. By Hudson bay. Yes it is full of trees, and farther from the equator than NH.
    If you install the puck correctly, you wont have any problems.
    Apr 2005
    Woops, my bad. Indeed I meant to say SIRF III not Sirf 4 !
    Quote Originally Posted by Quattro View Post
    2002 Honda CR-V
    Oct 2007
    1
  1. Getting Started with GPS
    By grepzen in forum The FAQ Emporium
    Last Post: 09-26-2006, 06:54 AM
  2. gps and external antenna
    By corsab in forum GPS
    Last Post: 09-22-2006, 03:51 PM
  3. Holux GM-213 USB GPS Receiver, Good?
    By girbot in forum GPS
    Last Post: 04-24-2006, 12:35 AM
  4. WTB: external usb slim dvd drive enclosure and gps reciver
    By wabibito in forum Classified Archive
    Last Post: 04-13-2006, 12:22 PM
  5. USB GPS receiver For Ext Antenna?
    By McGreggor in forum GPS
    Last Post: 08-01-2005, 05:07 AM
