Important Notes
- uninstall any previous versions of Centrafuse before installing the latest release
- when listening to Radio or XM, voice recognition will not properly work unless you have a USB or Bluetooth microphone, this is due to buffering/recording
- when I refer to adding parameters to the application it is best to add it to your desktop shortcut in this format, make sure parameters go outside the quotes: "C:\Documents and Settings\David\Desktop\Centrafuse\centrafuse.exe" -nowarning -nolimit
New Features
- added HQCT config XML which allows you to set Bass, Treble, Loudness, Volume, and Seek Sensitivity
- added support for the Silabs USB radio, provided by MediaCar Australia
- removed rebuild button on the rebuild dialog, it starts rebuilding as soon as it loads with a cancel button
- added support for IMAP in email client
- email client works with TLS/SSL
- added multiple sound card support, you can set the music device and the record device to any sound card on the system
- added car in motion check to web links
- added additional main page with 6 extra button actions
- improved SMS message reading in phone
Bugs Fixed
- removed disable navigation option in settings, it was no longer used
- Cinergy600 support has been fixed
- license files are properly removed when application is uninstalled
- fixed single click issue not loading favorites
- fixed adding all favorites to queue
- XM properly un-mutes audio when a phone call ends
- fixed loading of MapPoint 2006 navigation engine
- fixed rounding issue in navigation turn by turn list
- navigation map no longer shows ontop setup screen when entering setup from navigation
- keyboard control works in navigation, it no longer takes focus
- HDD and CD playlist switching properly works, the count stays correct
- deleting web favorites properly works
- navigation misplaced dialog no longer appears at the bottom of the map in fullscreen
- navigation 2D/3D and Day/Night settings are properly saved
- email client properly shows the body of the email
- fixed date issues with email client
- fixed error on first load when changing imperial to metric
- fixed navigation not remembering previous route
- fixed navigation not remembering map location
- fixed issue with XM not starting after hibernating from Media with XM loaded
- improved speed when loading navigation cities, streets, and postal codes
- fixed navigation address searching, previous addresses that could not be found properly work
- fixed navigation address number searching, you no longer have to use a leading zero, 9 goes to 9 in the list
- fixed issue with volume getting stuck and causing system errors
- fixed issue with fast forward and rewind getting stuck and causing system errors
david
