It is XP SP2, english.
I fixed the Phone issue and re-uploaded a new installer... It was a simple error with the installer copying the files to the wrong location...
I am still looking into the dxsetup.exe issue, need to know if it's XP or Vista and also the Weather issue which I'm not sure how that is happening since I didn't update any plugin installers yet...
anyone have weather working just fine?
david
site is down
Is this still a beta test, or does this one mean we have to buy the full version in 30 days?
Did you get an answer from destinator already about the nav plug-in without the maps?
www.superchargedmiata.net - all about roadster lifestyle
I have a different Weather issue. When I try to install the plugin, it tells me that it can't install it because there is already a newer version of the plugin installed. I don't have any Weather plugin installed (at least I didn't install the Weather plugin before, and it doesn't show up in the Settings list at all).
make sure to uninstall all your Centrafuse plugins and Weather should install... I plan to rebuild the installers with the new install program for all the plugins hopefully this afternoon...
david
The USB media playlist and counts seem to be fixed, thanks!
However, I had some CD playlist count problems arise this morning...
Last night when I left the car I had a CD loaded with a count of 1. I started up the car this morning, and the CD media loads again and makes the count 3!
I eject the media, and the count goes to 2. That's where I left it...
I should also note, with 1.14 sometimes the CD count would jump up to 2 randomly. I was able to correct it by manually cycling the day/night skin. That almost always brought it back down to 1.
Is it just me or are we introducing more bugs than where fixing as of late?
Also being June 15th. Store still seems to be offline.
The store is not up because I am testing the new installer and having some server issues we are trying to resolve due to really bad luck...
the issues are all from the new installer, which I had to switch to last minute because we had to move to installshield which was the main reason we delayed the launch in the first place, the old installer projects did not work properly with XLE versions...
we are working on everything trying to resolve all the issues...
david
The download has been fixed and the digital signature is no longer corrupted when the CentrafuseSetup.exe is downloaded... This makes the installer work properly on Vista as it should...
still trying to see why the weather plugin would not be working and trying to track down the one dxsetup.exe error I cannot find much information on or reproduce...
david
I just tested that the Weather plugin worked on 6 different machines and all allowed you to enter your location...
Still trying to quickly track down the issue one user had with dxsetup.exe...
ak47: Did it work after you uninstalled everything and tried again? Try to download the file again, I made changes to the download process...
Apologize about the server speed, I'm working with the cage right now, a router decided to mess up on the worst possible day
david
