Note that this is a final trial version and test serials will no longer work... Serial numbers and full XLE versions will be available late tomorrow on the website...
david
Centrafuse 1.2 Final is available on the downloads page.
http://www.fluxmedia.net/downloads
This version has a new multi-language installer and also properly installs on Windows Vista.
david
david
Any release notes to know what all you fixed from 1.14?
I got an error "Dxsetup.exe wan not marked for install" while trying to install 1.2 version. Should I uninstall 1.14 first?
I guess that means we have to buy this software now?![]()
Not have to. We finally get to.
1. Phonecontrol setup won't work?
2. The weather plugin wont let me choose a location.
3. XM still has the random static issue and requires multiple button presses sometimes to change channels.
The first 2 are major...
that is why I posted it before turning on the store... brand new installer last minute risky enough, but had to be done to even create the installs for the large XLE versions...
The XM issues are known and will be fixed soon... The weather plugin did not change and wasn't updated, I will look into that...
Not sure about the Phone issue, emailing Zoran now...
Also looking into the DirectX issue...
david
try to uninstall 1.14 and reinstall 1.2 and see if it works... What language Windows are you running? Is this on Vista or XP?
david
well Phone is not working because the installer copies it to the wrong location... You can drag the PhoneControl.NET directory from your root drive to the Centrafuse folder and it will work...
I'm fixing the installer now and will post an update in the morning...
david
