Results 1 to 10 of 13
Thread: Losing my setting?
    May 2007
    Losing my setting?
    Randomly now and then it seems as if Centrafuse looses the settings. It will start up saying welcome and guides me through setting up centrafuse .
    It seems as if it has something to do with improper start ups or shut downs, regardless. Why is it doing this? It is really annoying because it takes forever to reimport my library of 4000-5000 songs. Usually takes longer than the trip in the car. Plus the fact that I can't use the pc then.
    VENDOR - Centrafuse veetid's Avatar
    what version? Is it creating a error.log file you can post? the file would be located in your Centrafuse install folder for earlier releases, the latest it will be in LocalAppData\Centrafuse...
    somehow a file must be getting corrupt during a hard shutdown causing you to re-enter your settings...
    david
    May 2007
    latest version -- ill check for the log tonight.
    May 2007
    6/20/2007 5:27:43 AM
    The field is too small to accept the amount of data you attempted to add. Try inserting or pasting less data.
    at System.Data.OleDb.OleDbCommand.ExecuteCommandTextF orSingleResult(tagDBPARAMS dbParams, Object& executeResult)
    at System.Data.OleDb.OleDbCommand.ExecuteCommandText( Object& executeResult)
    at System.Data.OleDb.OleDbCommand.ExecuteCommand(Comm andBehavior behavior, Object& executeResult)
    at System.Data.OleDb.OleDbCommand.ExecuteReaderIntern al(CommandBehavior behavior, String method)
    at System.Data.OleDb.OleDbCommand.ExecuteNonQuery()
    at centrafuse.id3reader.ABJuSMysyhG(Int32 , Int32 , String )
    6/20/2007 5:57:58 AM
    Trying to revoke a drop target that has not been registered (Exception from HRESULT: 0x80040100 (DRAGDROP_E_NOTREGISTERED))
    at SHDocVw.IWebBrowser2.ExecWB(OLECMDID cmdID, OLECMDEXECOPT cmdexecopt, Object& pvaIn, Object& pvaOut)
    at AxSHDocVw.AxWebBrowser.ExecWB(OLECMDID cmdID, OLECMDEXECOPT cmdexecopt, Object& pvaIn, Object& pvaOut)
    at web.web.setTextSize()
    6/19/2007 6:10:58 PM
    6/19/2007 6:16:16 PM
    6/19/2007 8:08:54 PM
    May 2007
    Problem is... it's lost the settings after the 20th as well. And I'm pretty sure the date is correct. So maybe it didn't show up in the log?
    Quote Originally Posted by Ewout_vB View Post
    that does not look like a log from 1.20, is that what you were running on 06/19/07?
    try deleting the log completly, then make sure you are running 1.20, then wait for the error to happen again and post the log...
    david
    May 2007
    It's possible that is from before 1.20.
    I'll give it a try.
    May 2007
    It happened again, checking the error log now.
    May 2007
    The error log does not show any recent errors. It lost the settings this afternoon August 6 '07, the last error in the log is 06/22/07.
    Any ideas?
    Newbie ncervantez's Avatar
    Mar 2006
    Hemet, CA
    Same thing just happend to me again yesterday after shutting centrafuse down. It lost all my settings and even though it asks you to setup again it never will keep the settings unless I reinstall.
  1. Losing Sirf setting
    By garo in forum GPS
    Last Post: 05-23-2005, 06:05 AM
  2. Setting 1
    By ysutarko in forum FP Bug Reports
    Last Post: 04-01-2005, 03:07 PM
  3. Setting MODE 1
    By vicky_obee in forum FrodoPlayer
    Last Post: 03-10-2005, 01:40 PM
  4. uSDC20D Low Temperature Setting
    By zootjeff in forum Power Supplies
    Last Post: 02-12-2005, 02:50 PM
