Destinator can have some delay, but 100 meters seems like a lot...
anyone else having this issue?
david
When using navigagion in Centrafuse, what I see on the map is approx 100 meters behind where I'm actually driving. Example: When I pass a sideroad, on the map I actually reach this road after approx 100 meters.
I've tested with another navigation program, and there everything seems fine.
How can I solve this problem???
david
Can't say for sure if it's 100 meters, but it seems TOO much if you should drive in a big city with crowded streets and lots of turnings. The deleay I'm experience now is that much that I believe it will make me miss where to turn.
And as mentioned earlier it's quite a differece compared to other navigation programs.
It's not satisfying. It's a shame, as I finally found a Frontend that I really like, exept from this and that I quite can't figure out how transfer the phonesound (both listening and speaking) from my Sony Ericsson k700i (I can see when it calls and so on, but there's no sound???)
I have the same issue with phonecontrol and haven't had ANY luck on their forums about it.
Are you using a serial port splitter for your GPS or is it a straight connection? What GPS device?
I am getting the same problem with the destinator navigator; it is very slow to update where the car is and is definitely trailing behind by an unacceptable amount.
Life moves fast, so don't get left behind, buy a fast car!
I had this problems in one of the older CF versions with a borrowed GPS, then in the succeeding version it was fixed and then broke again for good in the version after again. Then I got my own GPS of another brand, no problems.
Same OS, gps driver etc in all attempts.
/SOS/
XP Pro, CF 2.0-newest| Pioneer HU with 7" flip-out (EQ, Surround)
Epia V10000 + nVidia FX5200, Opus 150w, 7" Lilliput, DVD* SlotIn, Wavelan, Bluetooth, GPS, WebCams, DVB-T
Same problem here!
Drive slower?
Hhaha, but I don't have any of the GPS delay with the bu-353. What receivers do you guys have?
I too have a bu353 and are getting the problem, however GPSinfo etc... all work fine, so it must be destinator causing the issue, or just taking that long to update.
I have the problem but only with my Bluetooth GPS, my cable one is fine.
