Results 1 to 10 of 12
Thread: HELP! Hibernation is not working properly...
    Jan 2007
    Minnesota, USA
    I've upgraded from CF 1.14 to CF 1.2. Everything worked great in 1.14. Turn the car on - the pc starts. Turn the car off - the pc hibernates. After the update here is what's going on: turn the car on - pc starts; turn the car off - nothing. The pc does not hibernates. Turn the car on again - the pc starts to hibernate and in the middle of the process it restarts. In the settings it set to hibernate. The jumper is set to mode 2 (5sec/2hour). I don't know if it is the CF's 1.2 problem or not but it worked great in CF 1.14.
    P.S. If I set the jumper to mode 1 (5sec/45sec) then when the car is turned off the pc will start to hibernate for about 10 seconds. Then it will start to restarting and will eventually shut down after the black Windows XP screen is shown.
    May 2006
    Belgium
    maybe it's a problem with some setting in your bios... something called "reboot on power loss" or something?
    not an expert, but it's worth looking what that setting is set to...
    Greetz
    Dj NRG
    Jan 2007
    Minnesota, USA
    Quote Originally Posted by Dj-[NRG] View Post
    Greetz
    Dj NRG
    Thanks, I'll look into that. Any idea what it should be?
    May 2006
    Belgium
    I think it should be set to not to reboot...
    Greetz
    Dj NRG
    Jan 2007
    Minnesota, USA
    Greetz
    Dj NRG
    Yes, that's what I have it set to. By the way, I haven't changed any settings when I upgraded from 1.14 to 1.2 and everything worked fine in 1.14.
    David, do you have any ideas?
    FLAC Nola111's Avatar
    Jan 2007
    New Orleans, LA
    I had this same problem in 1.2.
    Jan 2007
    Minnesota, USA
    Quote Originally Posted by Nola111 View Post
    Were you able to fix it?
    Jan 2007
    New Orleans, LA
    Unfortunately no. And it was one of several reasons that I ditched Centrafuse.
    Maximum Bitrate NiSlo's Avatar
    Nov 2006
    Gold Coast, Australia
    Have you tried changing the igntion off action in CF to none, closing out, restarting and changing it back to hibernate?
    Also check what settings windows itself has. I believe changing the settings in CF just changes the windows settings.
    Control Panel > Display > Screen Saver Tab > Power > Advanced Tab > Power Settings > Check what it says in the drop down box under "Do the following when I press the power button"
    I installed my carpc into my pet Kangaroo, mate.
    Jan 2007
    Minnesota, USA
    Quote Originally Posted by NiSlo View Post
    In windows it is set hibernate.
  1. Centrafuse RC3 Release Notes
    By veetid in forum Centrafuse
    Last Post: 08-21-2006, 12:09 AM
  2. Centrafuse XLE RC1 Release Notes
    Last Post: 07-12-2006, 04:48 PM
  3. 1.7 Progress report
    Last Post: 04-28-2006, 11:14 AM
  4. Rikaline 6010 hibernation not working.
    By skippy911 in forum GPS
    Last Post: 08-04-2005, 08:53 PM
  5. XMPCR has hibernation problems?
    By MikeH in forum FrodoPlayer
    Last Post: 09-24-2004, 11:08 PM
