Results 1 to 10 of 11
Thread: dvd rom via usb?
    May 2006
    Belgium
    dvd rom via usb?
    hi, i want to connect my dvd drive up front (pc is in my trunk) and i wanted to go for the usb to ide method to do this.
    my question is: if i connect my dvd drive via usb, how will CF recognize it? as usb device or as cd drive?
    Greetz
    Dj NRG
    VENDOR - Centrafuse veetid's Avatar
    if you have the right adapter it should be picked up in windows as a CD/DVD drive and work just fine....
    david
    May 2006
    Calgary, Alberta
    Have you thought about how you're going to power it?
    Ampie Case
    256 MB DDR2 PC5400
    Xenarc 700TSV - VGA Monitor
    Intel D945GCLF Motherboard
    M2-ATX-HV
    2005 Honda Civic
    May 2006
    Belgium
    Quote Originally Posted by Maheriano View Post
    ?? usb powers it, like it does with all the 2.5" drives etc...
    there is an adaptor for a slimline dvd witch makes it to a normal IDE plug, and then you have a seperate power connector, but if you don't use that adaptor, then you have a small ide connector (2.5") and then you don't have a seperate power connector, since the power comes from usb...
    at least that's what i thought, correct me if i'm wrong...
    Greetz
    Dj NRG
    May 2006
    Calgary, Alberta
    oh wow, didn't know that
    Ampie Case
    256 MB DDR2 PC5400
    M2-ATX-HV
    2005 Honda Civic
    May 2006
    Belgium
    well, some slim line dvd roms are like i described, mine isn't...
    so i'm gonna need a power connector... but i allready have one in front of my car, so no problem
    Greetz
    Dj NRG
    Mar 2006
    I have an external case for my slim drive and I have tested it on my computer (this one). It definitely needs a separate power source. I have read on here that using the 5v from a molex connector is the best.
    Maximum Bitrate binary.h4x's Avatar
    Jun 2003
    Fairfax, VA
    Quote Originally Posted by hornyleprechaun View Post
    True
    Feb 2006
    i got a lil 15 watt voltage regulator that i just tapped into a wire in the front dash where the OEM radio used to be to power the usb hub in my dash and a couple other things
    May 2006
    Belgium
    i'm buying one of those adaptors from ebay, which transfers the ide connector to usb, so i just have to plug in a molex and that's it...
    Greetz
    Dj NRG
  1. WTB: usb gps receiver & dvd rom
    By vile10 in forum Classified Archive
    Last Post: 12-08-2005, 01:27 AM
  2. stupid usb slimline DVD drive
    By ummagawd in forum General Hardware Discussion
    Last Post: 04-26-2005, 01:57 PM
  3. DVD Rom IDE to USB, 25ft. would it work?
    By mattress in forum General Hardware Discussion
    Last Post: 02-04-2005, 03:03 PM
  4. WTB: Slim DVD ROM and USB GPS Mouse
    By cdevelasco in forum Classified Archive
    Last Post: 01-22-2005, 11:28 PM
