I believe that the CF maps are different, hence your problems. You can wait for David to answer on here or you may want to try the CF forums for a quicker answer.
Hey everyone. Sorry if this has been asked before but I did extensive searching before deciding to post and was unable to come up with an answer. I tried using Destinator 6 maps with CF and when I extract them and put them in the CF folder, load up CF, go to Nav, Change Maps and select the map I want, I get a little window popup saying
Any ideas what this could mean or what I need to do to remedy this? The maps are 2006.Q2.Your current map Mid Atlantic (DC DE MD PA VA WV) is erased or damaged! Replace the current map.
I noted in a previous post that another user's Destinator map folders were labeled CANADA, USA1, USA2, etc. The ones I have on my CD are labeled as "East Central (MI IN OH KY TN)", "North East (CT MA ME NH NJ NY RI VT)", etc. I also tried renaming the folder to just "MidAtlantic" without any spaces in case it was an issue with spaces or folder name length.
Thanks for any help anyone can offer.
| 06 Mitsubishi Raider Durocross |
| CarPC Project:________________ |
| Planning: [*******-------] 50% |
| Carputer: [********------] 60% |
| Fabrication: [*----------] 10% |
Bump? David?
Maps from Flux should only be used with Centrafuse if using the integrated Destinator...
david
