Results 1 to 3 of 3
Thread: problem to load POI in centafuse
    Aug 2007
    hello… I am using centrafuse with navigator DESTINATOR, have found a POI for destinator and that is in format .dat and .bmp , but inserting them in the folder of the Italy map , they do not come recognized from the program, and in fact it does not load them, the file that I see in the folder of the Italy map of destinator begin all with: WCE, and I find WCE_A.MAP, WCE_A.COV, WCE_A.TAB, WCE_A.TRL, WCE_A.POI, WCE_A.TMC, WCE_A.DAT, WCE_b1.dat, WCE_B2.dat…
    that conversion I must make? how I can load POI in the software destinator?
    thanks....<br /><br />
    Maximum Bitrate tolisn's Avatar
    Dec 2003
    Greece
    If you look into the directory that centrafuse creates you will find a directory with a name UserData inside that there is another directory name Favorites. Place your POI data in that directory and not in your map folder.
    The road is long but we are getting there.
    Aug 2007
    thanks for answer...I have inserted the new POI in the folder advised from TOLISN, but after to have open the program, I find only the old , and the new POI not inserted...
    I have noticed that in this folder there are many file .bmp and one only .dat, name “my favorite”....my file .dat are many and distinguished for categories...
  1. Not your typical flicker problem
    By JPuma in forum LCD/Display
    Last Post: 05-30-2007, 10:28 AM
  2. had an all day (9 hr) problem at work....
    By wizardPC in forum Off Topic
    Last Post: 10-20-2005, 12:50 PM
  3. frodo just quits on load?
    By gummybear in forum FrodoPlayer
    Last Post: 09-25-2005, 02:12 PM
  4. OPUS point of load
    By lostreception in forum Power Supplies
    Last Post: 06-15-2005, 11:46 AM
  5. load soft ware to usb hard disk then load to comp
    By tracker92 in forum General Hardware Discussion
    Last Post: 08-29-2004, 07:57 PM
