You can set auto startup in settings.
I haven't gotten to install or test centrafuse yet.
I'm getting the xle version and want to know do how do I get centrafuse to start up automatically when xp starts up? I already got rid of the windows starting screen. Does centrafuse autoload on default? or do I need to make some windows changes?
you can set the run as shell in Centrafuse if you want to replace the entire system shell, or simply just move the shortcut into the Startup folder...
david
it should start a little faster... you can just try it and see how it works for you...
david
Thanks for the answer.
But If I test this option, could I return back if it's not appropriate to me without damaging Windows?
yes, you should be able to go right back into settings, set run as shell to OFF, then reboot and Explorer will load back up...
david
No matter what i try i can't get centrafuse to run as shell.
Win 7 32bit
fitpc2
Same thing for me ... :-(
I cant get centrafuse running as a shell in win 7, used to work on xp fine, must be a win 7 thing, i have the short cut in start up folder and that boots into centrafuse pretty quick
