Ok yeah sorry, I guess I was a little confusing.
Ok here's the deal. I went out and re-tested with both patch and non-patch, and it does look like the 1.46 Patch caused the problem. I rolled back to regular 1.46 and everything populated fine in the list... HOWEVER, even in 1.46, the song info still does not update unless you press the channel. So basically when you start the module, it will load the entire list with whatever artist and song is currently playing on each channel, but nothing of those will ever change unless you select a channel. Then that one channel updates itself.
Here are two logs for you
Thanks!
