Page 20 of 26 FirstFirst ... 1011121314151617181920212223242526 LastLast
Results 191 to 200 of 252
Thread: XM / Sirius Worklog
  1. #191
    VENDOR - Centrafuse smeesseman's Avatar
    Mar 2007
    Detroit, MI
    Quote Originally Posted by Nola111 View Post
    Scott, good news. Looks like the station text issue is resolved! I've only tested so far with the few stations I listen to the most, but I also watched the other stations that were viewable in the screen, and they were updating themselves. Thanks!
    Good deal
    So back to that SPDIF issue. First thing I want to point out is that I'm definitely on "SPDIF" in settings, and I was in the last dll version as well, even though you were saying you saw NONE in the log.
    That was a problem, and did fix it in 1.466, I was hoping it would fix the spdif muting issue as well, looks like it didn't...
    2nd thing I should point out... when I go into Sat. Radio settings in this latest version, when I press 'Save', and then press Yes to confirm overwrite, it just stays on that same settings page, as opposed to going back to the previous screen like it should. Maybe this is why it thinks it's NONE? Because it's not truly saving the settings??
    Will look into...
    EDIT: Can you post your CF error.log? Might need that for this one, looks like there may be an exception happening in the code... Best scenario would be to clear error.log, open CF, go into settings, reproduce issue, close CF, check error log to see if anything has been written to it, let me know if not, or send me log if so...
    Ok, so on the issue of the SPDIF playback line. It's a gray area as far as knowing how much the functionality belongs to the XM plugin, and how much of it belongs to Centrafuse's code. I mentioned it to again to David in the 1.46 thread, and he said he's still looking into it, and also to try and keep the discussion of it in this thread for organization purposes.
    As far as Buffer mode goes, there's still a problem where I have to go to the Windows mixer and manually select the SPDIF record line to get audio. I didn't have that issue in earlier versions of SatRadio. It seemed to at least work in Buffer mode.
    All that will hopefully be moot anyway because I need to use Sat Radio in non-buffer mode because of my mic being plugged into my soundcard. The ultimate goal here is to get Centrafuse/XM plug to unmute the SPDIF PLAYBACK line when entering the XM module, and to remute it when starting media playback, or exiting Centrafuse.
    David is fully aware of this, but I wanted to make sure you were too because I really have no idea how much of that is tied to the XM module itself.
    For your reference, my log from this morning is attached.
    I'm looking at the log and there is nowhere in the log where you switch from XM audio to another type audio, plus it looks like you are in buffer mode while running this log. Can you run in non-buffer mode, switch audio source a few times from XM to whatever, close CF, and then post that log? It might give me a possible clue about the plyback spdif line not muting...
  2. #192
    FLAC Nola111's Avatar
    Jan 2007
    New Orleans, LA
    Ok, I'll get you logs asap. Thanks.
  3. #193
    Jan 2007
    New Orleans, LA
    Bump to get back to the top of the list due to this morning's server issues...
  4. #194
    Jan 2007
    New Orleans, LA
    Ok Scott, we are SO close to being there. The remaining audio issue may be more David's area... not sure.
    First off, let me say there is a problem with the CF error.log. I cleared it out and started fresh as you suggested, but now it's not logging anything in there. The log file remains blank even after I played with CF for over 20 minutes.
    Ok, now for the SPDIF stuff. I turned buffer mode off (It still appears that the Sat Radio settings cannot be saved, however if you cancel out of the settings page and go back in, it does appear to have saved any changes you've just made). Now it seems that switching back and forth between XM and Mp3's works. But, it still acts like Buffer mode. What I mean is that the SPDIF Playback line still isn't being touched at all. (I'm pretty sure David is still looking into this). Even with buffer mode turned off, it's still controlling the audio switching through the Record lines of Windows mixer. If I didn't need the record line of my Line-In/Mic, this wouldn't be a problem, but I do. Post #117 of this thread has the screenshots of all my Windows Mixer channels, should you need to look at them for reference.
    So again, I'll have to figure out the issue with CF's error.log and get that to you asap. In the meantime, here's the XM log if it helps you with anything with the audio.
    Otherwise, like I said in a previous post, the text issues are fixed... good job and thanks!
    Attached Files Attached Files
  5. #195
    VENDOR - Centrafuse veetid's Avatar
    I'm looking into the SPDIF, it should be working... I finally received some USB sound cards with SPDIF so I can set them up and try to reproduce the issue and fix it...
    The error.log not having anything written to it is not an error, it means no errors happened in Centrafuse to log...
    david
  6. #196
    Jan 2007
    New Orleans, LA
    Quote Originally Posted by veetid View Post
    david
    Well that would make sense Well then I don't think the error log would have done Scott any good prior as there weren't ever really any errors happening as far as CF was concerned.
  7. #197
    Mar 2007
    Detroit, MI
    OK looked at the log, everything seems to be going the way it should. So, just to make sure, everything works for you when Buffer is ON, but you can't use the Buffer due to your MIC, so you want to have Buffer OFF. But when BUFFER is OFF, CF does not mute/unmute the SPDIF playback line properly, thus it will not ever let the XM audio through?
    David, just an FYI -
    It looks like evreything is good on the SatRadio end, we're calling the CF_setMixerMute() method with SDPIF as argument, just doesn't seem to be doing anything for him, if I am understanding correctly...
  8. #198
    Jan 2007
    New Orleans, LA
    TIME OUT Scott and David! Something magical has happened.
    So I get in the car this morning, fire up Centrafuse, and open my mixer as usual for testing purposes, and what the heck?! XM is working correctly with the SPDIF Playback line!!!!
    The only explanation I can come up with is that yesterday when I changed to turning Buffer Mode OFF, CF truly did not save the settings, as I mentioned in earlier posts... but then either a reboot of the pc or maybe even just a restart of CF, DID save the settings.
    XM now works exactly the way I've been wanting it to! Thanks guys!
    (I do have one more test to try... I had to rush out of the car late for work today, so I did not get to test switching between XM and mp3 this morning. I'll verify that later today).
    So it seems to me you guys just need to look into the issue with the settings not getting saved as normal.
  9. #199
    Jan 2007
    New Orleans, LA
    Scott,
    I have one final request for XM functionality. Again, on this one, I'm not sure if yours or David's area:
    Right now, the only way to stop XM audio is to either switch to other media, or close Centrafuse. Well, in most circumstances, my routine is to, while listening to XM, close CF and hibernate my pc. When I return and start up CF, XM audio automatically starts since that's what was playing when I closed CF. This is actually a great feature, BUT, sometimes I want to have control of this and tell CF that I don't want any audio at all playing when I open it. Currently, the only way to do this as far as XM audio is concerned, is to switch to mp3, then stop the mp3, then close CF. In other words, there's no manual way to stop XM audio once you're in the XM module.
    The solution? A simple Stop button for XM. This is what they have in SD. When I'm exiting SD, I hit the stop button first, and XM audio stops. Then when I return to SD, no audio is playing until I tell it what to do.
    Easy enough to code, or no?
  10. #200
    Jan 2007
    New Orleans, LA
    Scott,
    Looks like there is an issue when using XM in buffered mode, and another user verified in another thread that they have it too: When listening in buffered mode, after a few minutes (maybe 3) the title bar on the top left of the screen changes to "Buffered Audio, " and it will not change back to the name of the song unless you change the channel, then change it back to the station you were on. After that, another 3 mins goes by, and same thing all over again.
    I assume you need a log. I'll get you one as soon as I get back to the car.
  1. Replies: 42
    Last Post: 12-11-2009, 02:36 PM
  2. XM = Sirius! Merger Reported
    By lostreception in forum General MP3Car Discussion
    Last Post: 02-20-2007, 09:53 AM
  3. Got XM to work, then it took a dump
    By DuDs in forum StreetDeck
    Last Post: 05-06-2006, 05:42 PM
  4. XM Satellite Radio to Unveil XM Advanced Services at 2006 Consumer
    By Will Albers in forum General MP3Car Discussion
    Last Post: 03-27-2006, 08:49 PM
  5. Sirius vs. XM...? what up Gee?
    By mindscream in forum Car Audio
    Last Post: 10-24-2004, 03:31 PM
