PHP Code:
5/9/2007 11:30:37 AM
Input string was not in a correct format.
at System.Number.StringToNumber(String str, NumberStyles options, NumberBuffer& number, NumberFormatInfo info, Boolean parseDecimal)
at System.Number.ParseInt32(String s, NumberStyles style, NumberFormatInfo info)
at centrafuse.main.loadEQ()
5/9/2007 11:31:47 AM
Index was out of range. Must be non-negative and less than the size of the collection.
Parameter name: index
at System.Collections.ArrayList.get_Item(Int32 index)
at SatRadio.satradio.tuneChannel(Int32 channel)
9/5/2007 11:34:51 AM
Could not find a part of the path 'C:\Documents and Settings\Administrator\Application Data\CFBluetoothControl\Temp'.
at System.IO.__Error.WinIOError(Int32 errorCode, String maybeFullPath)
at System.IO.Directory.InternalGetFileDirectoryNames(String path, String userPathOriginal, String searchPattern, Boolean includeFiles, Boolean includeDirs, SearchOption searchOption)
at System.IO.Directory.GetFiles(String path, String searchPattern, SearchOption searchOption)
at System.IO.Directory.GetFiles(String path)
at CFBluetoothControl.BluetoothControl.UninitBluetooth()
5/9/2007 12:02:14 PM
Could not find file 'C:\Documents and Settings\Administrator\Local Settings\Application Data\Centrafuse\Presets\custom.xml'.
at System.IO.FileStream.Init(String path, FileMode mode, FileAccess access, Int32 rights, Boolean useRights, FileShare share, Int32 bufferSize, FileOptions options, SECURITY_ATTRIBUTES secAttrs, String msgPath, Boolean bFromProxy)
at System.IO.FileStream..ctor(String path, FileMode mode, FileAccess access, FileShare share, Int32 bufferSize)
at System.Xml.XmlDownloadManager.GetStream(Uri uri, ICredentials credentials)
at System.Xml.XmlUrlResolver.GetEntity(Uri absoluteUri, String role, Type ofObjectToReturn)
at System.Xml.XmlTextReaderImpl.OpenUrlDelegate(Object xmlResolver)
at System.Threading.CompressedStack.runTryCode(Object userData)
at System.Runtime.CompilerServices.RuntimeHelpers.ExecuteCodeWithGuaranteedCleanup(TryCode code, CleanupCode backoutCode, Object userData)
at System.Threading.CompressedStack.Run(CompressedStack compressedStack, ContextCallback callback, Object state)
at System.Xml.XmlTextReaderImpl.OpenUrl()
at System.Xml.XmlTextReaderImpl.Read()
at System.Xml.XmlLoader.Load(XmlDocument doc, XmlReader reader, Boolean preserveWhitespace)
at System.Xml.XmlDocument.Load(XmlReader reader)
at System.Xml.XmlDocument.Load(String filename)
at centrafuse.playlistManager.loadEQPreset()
at centrafuse.playlistManager.loadXML()
5/9/2007 12:02:25 PM
5/9/2007 12:02:30 PM
5/9/2007 12:03:53 PM
5/9/2007 12:04:15 PM
5/9/2007 12:04:26 PM
5/9/2007 12:04:31 PM
5/9/2007 12:19:23 PM
5/9/2007 12:21:18 PM
