Page 4 of 26 FirstFirst 1234567891011121314 ... LastLast
Results 31 to 40 of 252
Thread: XM / Sirius Worklog
  1. #31
    VENDOR - Centrafuse smeesseman's Avatar
    Mar 2007
    Detroit, MI
    Updated XM Plugin - V1.205
    Updated the XM plugin again. Please note right now these updates will erase your settings that were saved for XM. Do not save and restore the config.xml file as each update may have additional parameters added to it in config.xml... See Post #1 for all details...
  2. #32
    May 2006
    Seattleish, WA
    Hey! lookie what I found!
    Okay, there's a ton of info in here, but I don't think you & I are working on anything that you need. (correct me if I'm wrong of course!)
    One thing though is that CF's error.log is showing a string of errors of:
    Code:
    9/5/2007 5:03:22 PM
    SatRadio:The process cannot access the file "C:\Documents and Settings\Mark.PHRYD\Local Settings\Application Data\Centrafuse\Plugins\SatRadio\log.txt" because it is being used by another process.
       at System.IO.__Error.WinIOError(Int32 errorCode, String str)
       at System.IO.FileStream..ctor(String path, FileMode mode, FileAccess access, FileShare share, Int32 bufferSize, Boolean useAsync, String msgPath, Boolean bFromProxy)
       at System.IO.FileStream..ctor(String path, FileMode mode, FileAccess access, FileShare share, Int32 bufferSize)
       at System.IO.StreamWriter.CreateFile(String path, Boolean append)
       at System.IO.StreamWriter..ctor(String path, Boolean append, Encoding encoding, Int32 bufferSize)
       at System.IO.StreamWriter..ctor(String path, Boolean append, Encoding encoding)
       at SatRadio.satradio.DebugToFile(String msg, Boolean append)
    CF main has some real issues though... David's writing this error about 15 times/minute:
    Code:
    9/5/2007 4:59:49 PM
    Index was out of range.  Must be non-negative and less than the size of the collection.
    Parameter name: index
       at System.Collections.ArrayList.get_Item(Int32 index)
       at centrafuse.Plugins.skinListbox.OnPaint(PaintEventArgs pe)
    I'll send that along in another thread.
    :: Mark
  3. #33
    May 2006
    Seattleish, WA
    Quote Originally Posted by smeesseman View Post
    Hey Scott - as a suggestion, can you please name the ZIP file with a version number?
    I pulled the zip file from the link before you got to updating the first message, and the DLL is timestamped 7:57pm. Given the timezone change, I think that's right, but if the ZIP was named _1205 we'd know for sure.
    :: Mark
  4. #34
    Mar 2007
    Detroit, MI
    Quote Originally Posted by midiwall View Post
    David's error.log - Known issue, should be fixed, are the favorite icons working? That error was from the favorite icons not working. If theyre not working I didnt update the dll to the latest, let me know...
  5. #35
    May 2006
    Seattleish, WA
    Favs icons as in the station icons in as shown in the XM favs list? Yeup, they be there.
    :: Mark
  6. #36
    Mar 2007
    Detroit, MI
    Updated Build V1.206 - Garbled Info Bug Fixed
    GOOD NEWS ALL ! - I have been able to reproduce the infamous garbled data bug and have issued a fix. See Post # 1 for details...
  7. #37
    May 2006
    Seattleish, WA
    Woohooooooooooooo!!!!!!!!!!!!!!
    :: Mark
  8. #38
    Mar 2007
    Detroit, MI
    Quote Originally Posted by scostell View Post
    I am using the following setup for XM
    - Mp3Car USB adapter for XM Direct (purchased from mp3car store)
    - XM Direct (purchased from mp3car store)
    - Windows XP sp2
    - Via 130000
    Problem
    No station names appear, or any words at all for that matter. All that appears are numbers. The current song playing does not show up either.
    Example
    Station 141 - 88827167
    Station 142 - 329
    Station 143 - 901-222-0987 (sometimes it looks like a phone number)
    I know other people are having this problem as there is an entire thread dedicated to it.
    http://www.mp3car.com/vbulletin/1080326-post25.html
    It seems as though the problem occurs with people who have the same XM setup as I do (Mp3Car USB adapter with XM Direct).
    -Scott
    I think I have this fixed. Please try the latest download in Post #1...
  9. #39
    Mar 2007
    Detroit, MI
    I just meant the icons in the right side of the list, for the stations that are marked as favorites. Those are working now?
  10. #40
    May 2006
    Seattleish, WA
    Ahhh! The stars? Umm, I'll check this morning. I usually just stay in the FAV list so I wouldn't see the icons. Is this something that would have been fixed at 1205? I know they're not there at 1204.
    :: Mark
  1. Replies: 42
    Last Post: 12-11-2009, 03:36 PM
  2. XM = Sirius! Merger Reported
    By lostreception in forum General MP3Car Discussion
    Last Post: 02-20-2007, 10:53 AM
  3. Got XM to work, then it took a dump
    By DuDs in forum StreetDeck
    Last Post: 05-06-2006, 06:42 PM
  4. XM Satellite Radio to Unveil XM Advanced Services at 2006 Consumer
    By Will Albers in forum General MP3Car Discussion
    Last Post: 03-27-2006, 09:49 PM
  5. Sirius vs. XM...? what up Gee?
    By mindscream in forum Car Audio
    Last Post: 10-24-2004, 04:31 PM
