Page 1 of 26 1234567891011 ... LastLast
Results 1 to 10 of 252
Thread: XM / Sirius Worklog
    FLAC Nola111's Avatar
    Jan 2007
    New Orleans, LA
    Test. Possible forum troubles...
    May 2006
    Seattleish, WA
    Quote Originally Posted by veetid View Post
    I spent some time since the release is taking awhile to make the next 1.47 update not change your settings, so you should be able to update...
    david
    Thanks David! I'll keep an eye out.
    :: Mark
    May 2006
    Seattleish, WA
    Quote Originally Posted by Nola111 View Post
    wow... whoops.
    :: Mark
    VENDOR - Centrafuse smeesseman's Avatar
    Mar 2007
    Detroit, MI
    XM / Sirius Worklog
    XM/Sirius Plugin Ready For Use !!!!
    NOTE: A log file will be created in the c:\Documents and Settings\UserName\Local Settings\ApplicationData\Centrafuse\Plugins\SatRad io directory. Any users experiencing problems please send me or post this log...
    WORKLOG :
    EDIT: 1/6/2008 9:10 PM EDT
    Version 1.466, Compiled for CF 1.46+
    IMPORTANT NOTE: This version includes satradio.dll only, be sure to extract to c:\ProgramFiles\FluxMedia\Centrafuse\Plugins\SatRa dio
    * Attempted fix for issue with SPDIF line selection
    * Attempted fix for main title not populating on application startup when xm resumes audio
    Version 1.465, Compiled for CF 1.46+
    * Fixed small issues with timing when tuning station
    * Attempted fix for station list text items buffering up when satradio is not playing
    EDIT: 1/6/2008 3:00 PM EDT
    Version 1.464, Compiled for CF 1.46+
    * Attempted fix for issue with XM/Sirius re-starting from hibernation when last audio source
    EDIT: 1/6/2008 11:36 AM EDT
    Version 1.463, Compiled for CF 1.46+
    * Another attempted fix for issue with XM/Sirius starting from hibernation
    EDIT: 1/5/2008 11:00 PM EDT
    Version 1.462, Compiled for CF 1.46+
    * More debug logging added to help resolve last remaining issues
    EDIT: 12/20/2007 3:30 PM EDT
    Version 1.461, Compiled for CF 1.46+
    * Attempted fix for issue with XM/Sirius starting from hibernation along with media
    EDIT: 12/11/2007 9:30 PM EDT
    Version 1.451, Compiled for CF 1.45+
    * Fixed issue with XM/Sirius not starting up correctly and refreshing stations when satradio is run for the first time (after CF install)
    EDIT: 11/19/2007 7:35 PM EDT
    Version 1.431, Compiled for CF 1.43+
    * Fixed issue with terrestrial signal % being cut off in Onyx WS Skins (XM and Sirius)
    * Disabled station info updates when SatRadio screen is not visible, saving some CPU usage (XM and Sirius)
    * Improved Sirius main title update for when song changes
    * Fixed Sirus device mute/unmute bug where Sirius device sometimes started muted
    EDIT: 11/17/2007 12:45 AM EDT
    Version 1.430, Compiled for CF 1.42/1.43+
    * Removed channel # and channel name from main title
    * Added Channel # to subtitle label, underneath main title
    * Added channel name to header in listview of SatRadio screen
    * Improved main and sub title text updates on station changing
    EDIT: 11/10/2007 1:35 AM EDT
    Version 1.42, Compiled for CF 1.42 only...
    IMPORTANT NOTE: This version is included in the main Centrafuse 1.42 update only. There is no seperate download for this update.
    * Stations not populating bug for Sirius - fixed
    * Satradio not being muted / unmuted when using other audio sources - fixed
    * Put in code for Sirius station auto messaging, should fix problem with main title station info not updating correctly when song changes
    * Buffering now working very well - part of CF main update.
    * Visualizations working much better now - part of CF main update.
    * Non activated Sirius device will now tune to Ch 184 to wait for subscription change
    * Improved Channel images
    * Favorites are now preserved after performing a channel refresh.
    * Attempted fix for when sirius device occasionaly does not send checksum byte and satradio app hangs waiting for it
    EDIT: 10/23/2007 12:35 PM EDT
    Version 1.410, Compiled for CF 1.40+ only...
    IMPORTANT NOTE: This version requires that you also download a 2nd zip file containing the centrafuse.exe and cfplugin.dll files. These files must be placed in your Centrafuse Runtime Directory (i.e. by default that's c:\ProgramFiles\FluxMedia\Centrafuse).
    * Second Attempt : Fixed Sirius bug where length byte escape character not properly being handled. Should fix any problems with channel list not fully populating.
    * Fixed buffer mode not being saved.
    * Attempt to fix improper positioning of visualization.
    * Fixed Sirius channel refresh bug, list refresh should be twice as fast now.
    EDIT: 10/23/2007 1:05 AM EDT
    Version 1.409, Compiled for CF 1.40+ only...
    * Fixed Sirius bug in improper handling of certain byte pattern
    * Fixed list label not displaying sometimes when satradio screen is entered
    EDIT: 10/22/2007 8:25 PM EDT
    Version 1.408, Compiled for CF 1.40+ only...
    * Fixed Sirius bug where length byte escape character not properly being handled. Should fix any problems with channel list not fully populating.
    * Fixed buffer issues.
    * Fixed Buffer Position Label not being displayed.
    EDIT: 10/19/2007 10:05 PM EDT
    Version 1.401, Compiled for CF 1.40+ only...
    IMPORTANT NOTE: This vesrion will extract a centrafuse.exe and a cfplugin.dll to your C:\Program Files\Flux Media\Centrafuse\Plugins directory (the root of where you extract this zip too). These must be manually placed in your CF runtime directory as this plugin version requires those files to operate correctly. Back up the original files if you want incase you need to go back to them.
    * Added Sirius Images, updated XM Images.
    * Fixed Main Title text, text now scrolls with song and artist info.
    * Added Visualizations when buffer enabled, buffer still buggy though still
    * Main Title changes properly with song change.
    * Added autostart of XM/Sirius when CF loads (if XM/Sirius was last audio source when closed).
    * Added switching of Sirius/XM logo when Sirius/XM is selected in Settings.
    EDIT: 10/14/2007 3:28 PM EDT
    Version 1.209, First Version w/ Sirius Support, Compiled for CF 1.40 only...
    * Added first Sirius support, awaiting user debugging.
    * Fixed XM bug where list does not refresh completely.
    * Channel Refresh is now done by clicking listcount label at top of station list.
    EDIT: 9/10/2007 3:28 PM EDT
    Version 1.207 - 1.208
    * Fixed issue with system hibernation/resume, XM not working on resume.
    * Correct favorites icon now present in Skins folders
    * Added function to check config.xml, in this way we do not include config.xml in the zip file below, i.e. your XM Settings will not get erased every time you update the SatRadio plugin from this thread...
    EDIT: 9/5/2007 9:57 PM EDT
    Version 1.206
    * Fixed issue in system returning garbled data for station names and no data for song, artist names.
    * "Refresh Station List" function moved from Settings, now click list count at top of list to refresh
    * Added button in Settings to turn logging on and off, users who do not have problems can turn it off to prevent intensive log writing
    EDIT: 9/4/2007 1:13 AM EDT
    Version 1.204
    * Added more detailed logging for debugging purposes.
    * Added COM RX thread implementation
    - Should fix any issues with multiple clicks to change channels
    - Possibly could clear up other issues
    EDIT: 9/3/2007 5:07 PM EDT
    Version 1.203
    EDIT: 9/1/2007 4:48 AM EDT
    Version 1.202
    * pluginClose(), powermodeChange() event
    * Create missing LocalSettings Plugins/SatRadio
    * Add channel list saving on exit
    * Looking into shutdown bug with DVD player
    * Added Channel and StationName to MainTitle
    * Added automatic MUTE/UNMUTE Line functionality
    EDIT: 8/31/2007 11:52 PM EDT
    Version 1.201, First Test Version, Compiled for CF 1.20 ...
    * Debug logging added
    * Some small fixes caused by plugin migration
    * Channel images added back in to plugin version
    * Added shutown and hibernation code, untested
    TODO LIST - XM
    * Reports that after hibernate satradio stops working and device gets changed to XMPCR in Settings
    * Reports that XM does not mute/unmute when it should, 1 user having issues, works for most users
    * Buffer issues when playing for a while in buffer mode
    TODO LIST - SIRIUS
    * Reports that sometimes song title in main title does not refresh
    THANKS FOR YOUR HELP!!
    DOWNLOAD LINK
    XM / Sirius Plugin Package:
    Extract to c:\Program Files\Flux Media\Centrafuse\Plugins\SatRadio directory:
    * http://www.scottpm.com/cf/satradio/SatRadio_1_466_dllonly.zip
    Jan 2007
    I am using the following setup for XM
    - Mp3Car USB adapter for XM Direct (purchased from mp3car store)
    - XM Direct (purchased from mp3car store)
    - Windows XP sp2
    - Via 130000
    Problem
    No station names appear, or any words at all for that matter. All that appears are numbers. The current song playing does not show up either.
    Example
    Station 141 - 88827167
    Station 142 - 329
    Station 143 - 901-222-0987 (sometimes it looks like a phone number)
    I know other people are having this problem as there is an entire thread dedicated to it.
    http://www.mp3car.com/vbulletin/1080326-post25.html
    It seems as though the problem occurs with people who have the same XM setup as I do (Mp3Car USB adapter with XM Direct).
    -Scott
    Mar 2007
    Detroit, MI
    First test version of XM plugin has been posted, along with required support files centrafuse.exe and cfplugin.dll. See Post #1 for details. Please post your logs after running new XM plugin, it's time to get down to business with the XM issues...
    Mar 2007
    Detroit, MI
    Second test version of XM plugin has been posted. See Post #1 for details and download link. Please post your logs after running new XM plugin, it's time to get down to business with the XM issues...
    Mar 2007
    Detroit, MI
    Third test version of XM plugin has been posted. See Post #1 for details and download link. Please post your logs after running new XM plugin, it's time to get down to business with the XM issues... As the previous two updates, this is for debugging only, there are no fixed issues as of yet. I can't fix the issues until I can get someone with these problems to run the debug version, and send me the log file. This plugin has now had updates for a week, and no one has tested it yet. Anyone?
    May 2006
    Seattleish, WA
    Hey Scott;
    I'm still running 1.14 in the car which has been making me pretty happy all this time.
    I wasn't gonna move to 1.20 until I knew that someone was going to look at the XM issues. I didn't even know you were working on it until you posted up in the No song titles on XM thread on the 29th.
    I'll get 1.20 installed in the Bug and load this up for you.
    fwiw, this is my issues list:
    • Activating Buffered Audio for XM causes a major drop in volume. 6db or more.
    • Changing channels in Single Click mode is painful. It usually requires MANY (10+) clicks to get the audio to change. The channel display _does_ change immediately.
    • Channel numbering and Channel names are often confused. e.g., "Boneyard" is shown as the name for channel 82. The artist/title info seems to track correctly with the numbered station.
    • Audio is active only about 50% of the time after hibernate. About 70% of the time when this happens, multiple clicks of the station will bring audio back. The rest of the time requires an EXIT and reload of CF. (reboot is NOT necessary)
    :: Mark
    Jul 2005
    once done with the xm side, how long do you think it will take to have a working version of sirius, nothing perfect, just something we can put on our machines and test for you guys.
  1. Replies: 42
    Last Post: 12-11-2009, 03:36 PM
  2. XM = Sirius! Merger Reported
    By lostreception in forum General MP3Car Discussion
    Last Post: 02-20-2007, 10:53 AM
  3. Got XM to work, then it took a dump
    By DuDs in forum StreetDeck
    Last Post: 05-06-2006, 06:42 PM
  4. XM Satellite Radio to Unveil XM Advanced Services at 2006 Consumer
    By Will Albers in forum General MP3Car Discussion
    Last Post: 03-27-2006, 09:49 PM
  5. Sirius vs. XM...? what up Gee?
    By mindscream in forum Car Audio
    Last Post: 10-24-2004, 04:31 PM
