Results 1 to 4 of 4
Thread: with Iguidance Plugin, no gps anymore
    Mar 2007
    Ok, I downloaded the lastest verstion of centrafuse to get the plugin working for iguidance. well now, my gps does not work unless I right click on the delorme serial emulator and view "monitor for 3d fix", then after a second, it works and I guidance will work only by itself (not in centrafuse.) I'M NOT CHANGING ANYTHING WHEN I VIEW IT, I'M JUST OPENING THE MONITOR CHOICE AND ALL OF A SUDDEN, IGUIDANCE WILL WORK BY ITSELF BUT NOT IN CENTRAFUSE
    in centrafuse, I can't get any satellites or gps fix.
    the nav. settings in iguidance are only for the centrafuse mapping, not iguidance in centrafuse, right?
    or do i need to change baud rate and port settings in centrafuse?
    how the heck does installling centrafuse plugin stop my iguidance from working by itself now? this sucks
    Aug 2006
    change the port for the gps navigation in centrafuse to something else, don't set it to none. I had the same problem
    VENDOR - Centrafuse veetid's Avatar
    you can also go to page 4 and set the navigation engine to None, this will completly disable internal navigation, it will not even be loaded... This is what should be done if it is not being used...
    david
    Aug 2006
    cool didn't know you could disable it completely.
  1. iguidance GPS com port
    By shannara22 in forum Road Runner
    Last Post: 12-04-2006, 10:53 AM
  2. Newb - setting up XM and GPS iGuidance
    By XcompX in forum Road Runner
    Last Post: 08-31-2006, 12:25 AM
  3. iGuidance Font Size Fix summary thread
    By Viscouse in forum GPS
    Last Post: 03-28-2006, 07:21 PM
  4. Replies: 4
    Last Post: 11-16-2005, 11:15 AM
