Results 1 to 7 of 7
Thread: CFEmail
    Aug 2005
    CFEmail
    is it just me or any anyone else not install this plugin?
    keeps rolling back after install?
    im using the 30 day trial of 1.20
    VENDOR - Centrafuse veetid's Avatar
    I have installed this plugin just fine... Does it give an error that might help?
    david
    Aug 2005
    na it just installs , then when its finished it starts the roll back feture, then the next page saying that it wasn't installed, (its says it was interrupted)
    strange... do you have another computer you can test this on to see if it is something with that particular setup?
    Just install the trial on another machine, then the CFEmail plugin and see if it works...
    david
    Aug 2005
    sorry dav,
    just back from a long travel about 400 miles in total,
    this error might be related or it might not , i donno. but
    when i plot in a destination on the GPS from fav, then cancel it about have way (cause the map doesnt have the new motor-way) then re-plot in the same destination when i come to the raods that are on the map, then no voice prompts are given to me.
    the system also jammed once when i switched on the cam, but i'd say that was a fluke (hasn't happened since)
    i'll try and re-install the CF email on another system today
    Aug 2005
    ok CFEmail seems to work fine on my other pc , looks like i'll do a fresh install and hope for the best.
    David , have a read of this and tell me what you think.
    APOI Plugin: Netstumbler container + POI generator
    Aug 2005
    ok did a complete system wipe and a fresh install took all day, but i got it installed and working with Gmail
    Can you add in a voice notification to say something like "New Email received". (i take it that it checks for email even when the email window isnt open.)
    Reason being im used APOI and wifi hopper and if i drive / park next to a hot spot that i might get email and i wouldnt realise.
    Just an idea...
