Results 1 to 10 of 10
Thread: Warning at start. Solved!!!
    Apr 2007
    Thumbs up Warning at start. Solved!!!
    I have just bought the xle version of Centrafuse but even in this full version the sign with a warning about safe driving etc. comes up.
    Is there any way to disbable this warning without having to make a manual shortcut in windows start menu?
    After an advice from flux i had to create a shortcut and add some text after the file location. But my xp take a year to load so i would be very glad if i could skip the entire loading of xp.
    I hope you get idea of what i mean.
    Tonny
    Mar 2006
    Colorado, but Canadian!
    Centrafuse is not an Operating System. So you need an OS such as XP to load, then load the programs like Centrafuse.
    If XP takes a long time to load, you can optimize your install quite a bit. Check out nLite or just use the services disabler to keep all the extra crap from loading on window's start. If the BIOS takes a long time then you can optimize that as well.
    1.9in x 2.9in -- 47mm x 73mm
    May 2006
    Belgium
    or you could use standby or hibernation, so you don't shut down your pc, and don't have to wait for it to boot...
    Greetz
    Dj NRG
    Maximum Bitrate NiSlo's Avatar
    Nov 2006
    Gold Coast, Australia
    You can run CF as the system shell as well so that your desktop etc doesnt load, it just loads straight into CF. I do beleive there is swithces you can add to the registry to remove the warnings They are in these forums somewhere.
    I installed my carpc into my pet Kangaroo, mate.
    May 2006
    Seattleish, WA
    Other folks are covering the "getting rid of XP" side, but this post will help with the warning messages:
    http://www.mp3car.com/vbulletin/1027820-post15.html
    :: Mark
    Apr 2007
    Quote Originally Posted by NiSlo View Post
    This is what i ment. I´m currently having CF loading as the shell.
    But when i choose this option it comes up with the warning signs when loaded.
    If i choose to open xp first and then place a shortcut in start folder i can add a bit of text to makes theese warnings stop.
    I was looking for a little "guide" how to load cf as shell but without the warnings.
    May 2006
    Seattleish, WA
    Quote Originally Posted by 2nny View Post
    Try here:
    removing warning massage
    :: Mark
    Apr 2007
    That was just what i was looking for!!!
    VENDOR - Centrafuse veetid's Avatar
    also if run with warnings disable when you set to run as shell, it now properly adds everything to the registry on it's own... this was fixed in 1.30
    david
    May 2006
    Seattleish, WA
    Quote Originally Posted by veetid View Post
    ...once 1.30 is released.
    :: Mark
  1. Virtual Earth cache builder? Or even gps simulator to make it cache?
    By thepunkerguy in forum DigitalMods (Scripts / API)
    Last Post: 08-28-2008, 09:58 PM
  2. Indexing music in 1.0.9.8 Failed
    Last Post: 07-07-2007, 12:19 PM
  3. How do Mapmonkey autostart on RR start
    By xpluis in forum Road Runner
    Last Post: 04-08-2007, 01:52 AM
  4. Failed Hiding of Start Bar, Minimize Errors
    By DaRacerz in forum RR Bug Tracker
    Last Post: 11-04-2005, 05:36 PM
  5. RR doesn't start Phoco on initial load..
    By DutchBurner in forum Road Runner
    Last Post: 11-04-2005, 02:17 PM
