Try GPSinfo. Open it up and select your comport and then start. You shoudl see the raw data coming in in lower most text box.
Xport basically creates a copies the data coming in on the physical port (com 1) and provides a second virtual port (com 2) so that you can have two applications reading the gps data at a time. If you try using two gps programs reading one port, one of the applications won't be able to read what's coming in.
LinkBack URL
About LinkBacks
