Results 1 to 10 of 10
Thread: Reverse Cam autoswitch?
    Sep 2007
    I will be using carbuttons to hotkey to the cam screen when it detects the reverse light. However is there any way to swich back to whatever screen i was on before?
    IE show the cam when it detects reverse signal, and switch back when signal is removed.
    VENDOR - Centrafuse veetid's Avatar
    yes, there is a hotkey for switch to CAM and another hotkey for switching to Previous Section...
    david
    Sep 2007
    is there no way to swich back when the hotkey is released?
    not currently... you should be able to detect power on the line and send a hotkey and detect the release and send another...
    david
    Mar 2008
    can you explain a bit clearer for me?so i get power and ground from reverse light and hook up to carbuttons on gnd/an1. and how do i set it up in centrafuse to go to the cam. the site is down so i can't read anything. also you said about detecting a release. how would i do that? hook up gnd/power of reverse light in reverse polarity on carbuttons? (i.e. power -> gnd on carbuttons and gnd -> an2?)
    Newbie elBradford's Avatar
    Mar 2008
    Utah
    Quote Originally Posted by moto_noob View Post
    I did a quick search for carbuttons and the link to the vendor appears to be dead. Do you have a link for any more info? I would be very interested in installing such a device.
    Edit: It's still there, just drop the .html
    http://www.madhacker.org/carbuttons
    Pricy...
    monkey stole my pen
    My Worklog
    Mar 2008
    nah, i don't have any links. i don't have the carbuttons. but if i know how to work it, it'll probably try to search it somewhere.
    Dec 2005
    Raleigh, NC
    I'm still trying to find a similar solution. I want to monitor +12v from reverse and also for the dimmer and then switch to reverse automatically, and adjust screen brightness when I turn my lights on/off. Are there any good solutions out there? The FB seams like it could do it but requires a bunch of programming to get it to work and then there isn't a hot key for screen brightness.
    Nick - 08 GG Element
    Custom 3D-CAD Design, Reverse Engineering and Fabrication
  1. Which one is the 12v wire on this reverse cam (pic inside)
    By Sonicxtacy02 in forum General MP3Car Discussion
    Last Post: 02-08-2006, 10:26 PM
  2. Reverse engineering cam file...Proposal for $$
    By RoyN in forum Software & Software Development
    Last Post: 10-20-2005, 02:54 PM
  3. K301 Reverse cam wire
    By keanpedersen in forum LCD/Display
    Last Post: 08-15-2005, 05:53 PM
  4. reverse cam on xenarc video2
    By kuo in forum General Hardware Discussion
    Last Post: 05-29-2005, 01:33 AM
  5. * WRX STi Infrared Reverse Cam mounted in tail light *
    By LESLIEx317537 in forum General Hardware Discussion
    Last Post: 04-07-2004, 02:38 PM
