is it posible to delete warning mesage at startup in cf 1.2
And, if you're running CF as the shell:
removing warning massage
:: Mark
should be no workarounds needed with running as shell anymore if you are using 1.30... if you set run as shell while the flags are set, then it will do everything in the registry for you...
david
