Results 1 to 9 of 9
Thread: Centrafuse causing system not to Standby
    VENDOR - Centrafuse veetid's Avatar
    With the latest 1.30 or even 1.20, does Centrafuse still cause the system not to Standby/Hibernate for some users?
    I cannot reproduce this issue, but have it listed to look into...
    david
    Oct 2004
    NY
    I don't go into standby when cf is running, but if I press my power button it stands by fine, just not when set to the timer in windows...
    any info you need I'll try to get for you
    Constant Bitrate Lazyflip's Avatar
    Mar 2005
    FL
    Hibernate is working fine here.
    I tried to standby a couple days ago when I went to fill up for gas. I didn't wait for it to standby but when I went back to start the car the computer came on as if it were shutdown. I'll try it again later and see what actually happens.
    Jul 2006
    standby and hibernate working fine here if windows is set to do either upon pressing the power button. dont know if it works automatically after being idle
    Oct 2004
    NY
    I leave my tablet to standby automaticly after 15 minutes, it will just hang till the battery dies if cf is open, but if I tap the button, she standsby fine.
    this is winxp but tablet ed. not a big deal really as I will wire in auto control soon enough, & as long as it does work through the button it's not bad, but if theres anything I can check for you to find the bug lmk...
    Maximum Bitrate NiSlo's Avatar
    Nov 2006
    Gold Coast, Australia
    Quote Originally Posted by Lazyflip View Post
    That sounds like the PSU is cutting the power while in standby - it's not software related. If your computer is in standby and the power is cut (you remove the leys from the ignition and you PSU shuts off) when you try to resume it will strta with a normal cold boot.
    My standby works fine.
    I installed my carpc into my pet Kangaroo, mate.
    Jan 2007
    Minnesota, USA
    I used to have hibernation problem, but it works just fine now. I have 1.41 version.
    Oct 2004
    NY
    ok, I found out more now.
    when run as system shell, it won't stand by even with the button press, as soon as I exit from cf as shell, she stands by imediatley as explorer starts to load, I've got to change to not run as shell, then a restart, & then she'll stand by with a button press while running cf, but still not with the system timer set to standby at say 15 min or so.
    I really would like to run as shell eventually, is there something not starting maybe that I can get to start in shell that will enable standby with a button press?
    I will look into this...
    can anyone else reproduce?
    david
  1. Centrafuse SDK Information
    By veetid in forum CF SDK
    Last Post: 11-03-2005, 04:18 AM
  2. Security System thoughts
    By techy101 in forum General MP3Car Discussion
    Last Post: 07-28-2005, 04:42 AM
  3. Using standby with DC-DC system
    By adamis in forum Power Supplies
    Last Post: 12-01-2003, 11:19 PM
  4. Replies: 22
    Last Post: 08-13-2001, 02:42 PM
  5. Arise ACE-865V dc-dc ps, system wont post, help...
    By plasmadis in forum General Hardware Discussion
    Last Post: 07-17-2000, 03:08 AM
