This plugin is valid a "infill T3"?
Here is the Infill support bundled into an easy to use installer...
With Centrafuse 1.20 or greater installed, all you need is to install this plugin to setup everything for your Infill...
It will automatically setup all your radio settings and add the G4 plugin to the main menu...
http://www.fluxmedia.net/downloads/CFInfill.exe
It still needs a few translations, but I will get them added soon... Please help in testing if you have an Infill...
david
never tested, but heard it will work on the T3 as well...
won't hurt to try it...
david
I have installed plugin in infill T3, but the radio not work. I need aid, please.
do not have a T3 and this plugin is designed for the G4
david
