Did the device show up in TV settings?
david
Hello Just got the WinTV-USB-FM Device from ebay for a tenner so lucky me aey, got it working superb through centrafuse on fm radio, but when i switch over to TV i get a black screen with nothing, not even static. this all works perfect if i got through the wintv2000 app which comes with. i am running my radio through radiator and thought that the problem might occur due to the device already being used with the app causing it to be busy and hence not work but even after disabling the radio totaly and removing the radiator software; still no TV and no better either
Can someone out there help me, there must be away to have this ONE device work on both tv and radio! surely! HELP??
Thankyou Danny.
david
Yes, the device showed no problem, but just sat black on channel 3 and i was unable to even turn over. thankyou
Ideas?
no further help, i have kept playing with it but nope! nothing bah hooooo haha
also i was curious is DAB a function to which is being looked into in centrafuse at all
Hello, I have the same device, you can only use it for TV or Radio and you have to quit CF, run winTV or radiator (Depending if u want tv or radio) then restart CF again everytime you change the settings.
Besides, I think that this TV tuner's reception is quite bad, which antenna are you using ?
VIA EN15000 C7 // CTF700 7" Screen // Morex 3688 Black Case
M2-ATX // 80GB HD
DVD-RW // PowerMate
Belkin Bluetooth V1.2 // Hauppauge WinTV FM
Centrafuse RC5
JBL GTO 75.4 520W // Pionneer Kevlar 260w Speakers
i have a 20db in car aerial and works a treat! like i say though it wont intergrate in with the centrafuse interface whatso ever on the tv part. can only manage to have radio working
