Page 3 of 9 FirstFirst 123456789 LastLast
Results 21 to 30 of 89
Thread: Will this USB Radio Work?
  1. #21
    Aug 2006
    Pakistan
    GOT IT!
    I will install it and let you know how it performed.
  2. #22
    May 2006
    Seattleish, WA
    Quote Originally Posted by SUVputer View Post
    ordered one as well! hope it'll be easy to hack the antenna without breaking the box...
    INCREDIBLY easy. There's a single screw on the case. Undo it and the antenna slides right out. Slip a screwdriver blade into the case through the hole where the antenna was, twist a slight bit and.. pop! the case comes open. It's not glued along the edges so you won't end up with the marring that usually happens when you crack open a case.
    (click on pics for larger views)
    :: Mark
  3. #23
    Aug 2006
    Pakistan
    Working perfectly in Centrafuse. Reception is also good. Hardly no setup to perform.
  4. #24
    Apr 2007
    In the description I couldnīt see if the device support RDS/RBDS (Radio Text from FM Stations). Could someone be so kind and tell me whether this feature is available on this device or not. Thanks
  5. #25
    VENDOR - Centrafuse veetid's Avatar
    what radio module are you using with this radio?
    david
  6. #26
    Jul 2005
    ^^ Yes I'd like to know as well
  7. #27
    Aug 2006
    Pakistan
    Quote Originally Posted by veetid View Post
    david
    Silabs
  8. #28
    Aug 2006
    Pakistan
    Ok, reception is not good while in car. Looks like we have to attach car's main antenna to usb radio.
  9. #29
    May 2006
    Seattleish, WA
    Quote Originally Posted by oneteam View Post
    Okay, how would I know? Is that the "i" button in the CF radio module? I have it up and running here at my desk, so...
    I'll run through the local stations and see if I can find anything. Anyone know of a directory of (US, Seattle) stations that shows if they're broadcasting? n/m... I found rbds.net. hang on!
    okay, according to rbds.net KISW/99.9 should be spitting RBDS. I have it tuned in the CF client, the signal is nice and strong and the "i" button is lit. I'm not seeing anything different on the display. Can someone confirm that this feature is working in general with CF 1.20?
    :: Mark
  10. #30
    May 2006
    Seattleish, WA
    fwiw, the Silabs app isn't showing RDBS text either.
    update... the chip in this device is marked "Silabs F321 ECNA15 06124". I can't find that on the Silabs site. Still looking.
    update... the F321 is an MCU, so that's the USB handler and general brains. Still looking.
    The first stop for the antenna signal is a chip marked 4700A09. I can't find a reference. There aren't any house markings on it so I can't ID a manufacturer. My guess is now that the FM receiver itself is NOT Silabs, but the MCU is loaded up with code to emulate the Silabs protocol. I'll keep trying to ID this chip.
    :: Mark
  1. Core Duo / Core 2 Duo Mini-ITX boards
    By RedGTiVR6 in forum General Hardware Discussion
    Last Post: 10-03-2010, 11:30 PM
  2. Which USB Radio device
    By vqstatesman in forum General Hardware Discussion
    Last Post: 05-06-2007, 08:41 AM
  3. Radio stuttering, USB Speed Test?
    By hari-bhari in forum General Hardware Discussion
    Last Post: 02-09-2007, 12:43 PM
  4. USB Radio Crash!!
    By msreyes in forum StreetDeck
    Last Post: 08-16-2006, 09:06 AM
  5. Will IBUS work w/ carputer and radio????
    By BMW DZYN in forum General Hardware Discussion
    Last Post: 08-04-2005, 05:53 PM
