Page 4 of 9 FirstFirst 123456789 LastLast
Results 31 to 40 of 89
Thread: Will this USB Radio Work?
  1. #31
    Jun 2006
    all this is great, now we have to fix the car antenna to the radio and get the RDS working (if it's possible)!
    I bet that Brando guys are asking themselves why they suddenly a rise in demand for this product...
    VIA EN15000 C7 // CTF700 7" Screen // Morex 3688 Black Case
    M2-ATX // 80GB HD
    DVD-RW // PowerMate
    Belkin Bluetooth V1.2 // Hauppauge WinTV FM
    Centrafuse RC5
    JBL GTO 75.4 520W // Pionneer Kevlar 260w Speakers
  2. #32
    VENDOR - Centrafuse veetid's Avatar
    I have a couple of other Silabs issues, anyone with the devices interested in helping debug the radio module code? not many issues with it, I just don't have anymore working Silabs devices to fix, why they haven't been fixed yet...
    silabs does not seek/scan or save presets
    silabs radio module does not cut off when you exit or switch to media
    silabs not working on resume from hibernation/standby
    silabs does not always work with RDS
    Those are the reported issues with the radio module...
    david
  3. #33
    Maximum Bitrate NiSlo's Avatar
    Nov 2006
    Gold Coast, Australia
    David,
    I'm keen to sort the silabs module out. The main reason I'm not using the silabs at the moment is becuase of the cutoff issue.
    Let me know how I can help...
    I installed my carpc into my pet Kangaroo, mate.
  4. #34
    Aug 2006
    Pakistan
    midiwall, have you tried to connect main antenna to usb module? What's the game plan?
    Should we remove the original one, remove the main antenna plug and attach it the wire to usb module board?
  5. #35
    May 2006
    Seattleish, WA
    Quote Originally Posted by aghazi View Post
    I haven't tried it with the car antenna yet, but I did hang a wire off of the stock antenna to confirm the concept.
    Ideally you want to make a solid connection with the board, so I'll be soldering straight to it. I think I'll get a pigtail socket so that I don't actually tie myself to a specific antenna.
    Finding a socket looks like it's gonna be an issue... Hmm. I've been through the normal big electronics depots. Gotta find the right search term.
    ref "motorola connector": http://en.wikipedia.org/wiki/Motorola_connector
    :: Mark
  6. #36
    Aug 2006
    Pakistan
    OK, I removed the built-in antenna. Didn't open the box. Pushed the car's antenna's plug into that hole. Reception is fine but one problem. Whenever I turn on the LCD (Xenarc), reception got pretty low, lot of noise. If I turn LCD off (still plugged-in), reception got better. Any idea to overcome this?
  7. #37
    May 2006
    Seattleish, WA
    Yeah, I think you're gonna need to tie into the ground on the module, which is probably the same ground on the computer chassis.
    The issue you're having is the RFI/EMI from the LCD panel radiating back down the video line which itself is acting line an antenna. It'll get better if you shield the monitor, ground the antenna and/or wrap the video cable around a ferrite core. The latter two things will make more of a difference than shielding the monitor.
    :: Mark
  8. #38
    Nov 2004
    received this today and after 10 mins I realised that the fact that radio doesnt shut off when switching to media is a killer blow - if i can help fix this let me know, otherwise shelved this for now!
  9. #39
    lez
    lez is offline
    FLAC lez's Avatar
    Jan 2004
    UK
    Why is it everyone is having problems with the shutoff, the silabs software has no issue, so its obviously not being told to shut off or something needs unloading, as it creates a windows mixer device, could that just not be muted?
    Sorry if all that is no use I'm not using anything but silabs software, which works 100%, so I'm guessing at the problem, but it surely has got to be easier to /stop/ something working then making it work.........
    Lez, more widely known as flez1966
  10. #40
    Aug 2006
    Pakistan
    Quote Originally Posted by jwrpalmer View Post
    Strange, I am not having this problem. If I switch to media, radio shuts itself off.
  1. Core Duo / Core 2 Duo Mini-ITX boards
    By RedGTiVR6 in forum General Hardware Discussion
    Last Post: 10-03-2010, 11:30 PM
  2. Which USB Radio device
    By vqstatesman in forum General Hardware Discussion
    Last Post: 05-06-2007, 08:41 AM
  3. Radio stuttering, USB Speed Test?
    By hari-bhari in forum General Hardware Discussion
    Last Post: 02-09-2007, 12:43 PM
  4. USB Radio Crash!!
    By msreyes in forum StreetDeck
    Last Post: 08-16-2006, 09:06 AM
  5. Will IBUS work w/ carputer and radio????
    By BMW DZYN in forum General Hardware Discussion
    Last Post: 08-04-2005, 05:53 PM
