Page 9 of 9 FirstFirst 123456789
Results 81 to 89 of 89
Thread: Will this USB Radio Work?
  1. #81
    Constant Bitrate ronjon228's Avatar
    Dec 2005
    Grand Blanc, MI
    Yeah, I already read up about the HD radio solution. I paid $23.00 shipped for the USB radio. If it works, it's money well spent as far as I'm concerned. You can't expect these USB radios to work without a proper aerial. That's never going to happen. I think most people either don't take the time to properly hook one up, or do it incorrectly. It has to be grounded to the USB or it's going to suffer massive amounts of interference.
    If it doesn't work well in the car, I already will have an antenna installed and can easily go to HD radio. No loss except the $23.00 for the USB radio. It's worth it whether it works or not as far as I'm concerned.
    CarPC:
    1.8GHz Northwood, Intel 845 Mobo, 512MB DDR, 1x20GB + 1x160GB, Intel GPU, SB Live 5.1
    Sound System:
    Phoenix Gold RSD 65cs 6.5" Drivers, Infinity Tweets, Pioneer 305DVC 12", PPI Sedona 630IX, Alpine MRP-M500
  2. #82
    lez
    lez is offline
    FLAC lez's Avatar
    Jan 2004
    UK
    I use one of these in my car all the time, the silabs unit is the current best fm solution, the dll included with freeice is a very good work in progress, the skipping started a few weeks ago but its not as bad as once every ten seconds, sometimes I can go an 8 hr shift in the taxi without a skip, another night i may notice it 3 or 4 times, its this random nature what does not help find why it does it, but i think its got something to do with the way windows shares time slices etc.
    Lez, more widely known as flez1966
  3. #83
    dme
    dme is offline
    Jan 2008
    finland
    Is there any difference between this brando-radio and silabs-radio? Silabs has rds but brando doesn't? Where can i order cheapest silabs-radio?
  4. #84
    Oct 2007
    Guys can you tell me where to solder my motorola connecter extension cable to on this board please?
    There's the hole for the original small antenna and there's 4 points on the back of the board marked C2D, C2CK, GND and 5V(NC)
  5. #85
    Oct 2007
    I've wired the middle wire from the connector the hole on the board and connected the shielding to the outside of the usb plug but the reception is very touch and go.
    Please advise on how to improve this guys!
  6. #86
    BGH
    BGH is offline
    May 2006
    Melbourne, Australia
    Quote Originally Posted by Jabo View Post
    Yeah I'd like a bit of direction regarding this as well. Is grounding it to the outer sleeve of the USB connector the best thing to do?
  7. #87
    Jul 2008
    West Virginia
    Was just about to do this. Anyone give any tips before I tear into it?
  8. #88
    Constant Bitrate ankur's Avatar
    Aug 2006
    New Delhi
    OK i got the Brando radio and soldered on an antenna adapter, finally radio works although the signal is very low and i dont catch all stations. I am also using the standard silabs plugin for CF 2.
    I am facing a major problem, on exiting the Radio app the radio keeps playing and does not stop. Is this a common problem ?
    cheers.
  9. #89
    Jul 2008
    West Virginia
    Quote Originally Posted by blbrchnk View Post
    I did exactly as was said above and while it works, it doesn't work as well as my old regular radio and there is a great deal more static.
  1. Core Duo / Core 2 Duo Mini-ITX boards
    By RedGTiVR6 in forum General Hardware Discussion
    Last Post: 10-03-2010, 10:30 PM
  2. Which USB Radio device
    By vqstatesman in forum General Hardware Discussion
    Last Post: 05-06-2007, 07:41 AM
  3. Radio stuttering, USB Speed Test?
    By hari-bhari in forum General Hardware Discussion
    Last Post: 02-09-2007, 11:43 AM
  4. USB Radio Crash!!
    By msreyes in forum StreetDeck
    Last Post: 08-16-2006, 08:06 AM
  5. Will IBUS work w/ carputer and radio????
    By BMW DZYN in forum General Hardware Discussion
    Last Post: 08-04-2005, 04:53 PM
